[ROM] Paragon HD Series ROMS
Posted 18 February 2013 - 01:59 PM
"Welcome back my friends to the show that never ends We're so glad you could attend Come inside! Come inside!"
"Come inside, the show's about to start guaranteed to blow your head apart"
The Goods
9.1.39a base
HEAVILY modded hosts file (i havent seen an ad yet!) UPDATED
entire AC!D Audiomod package (finally reads headphones remote correctly)
4.2 keyboard, 4.2 camera and gallery working and and proper libs
debloated
deodexed
zipaligned
cpusleeper
root explorer
cpuspy
RPEngine 2
Crossbreeder engine
init.d support
there is more, i just cant remember i went through 20+ builds before i finally got it running perfectly.. lol enjoy guys
CREDITS
dhacker29
heyitslou
faux123
TEAM AC!D
everyone on the forums help and support (you guys keep me going!)
MOTOROLA
Xlightwarez & crackflashers and start for sources git and base
east2west
prstorero
ive had to rework alot from previous versions that didnt act the same from previous paragon series, will be adding stuff regulary on all series of my roms, and now that i work insane long days i will be opening up betas to allow people to use beta/stable builds, all the lines you know and love to come!
PARAGON MAXXIMUS v2.2HD
- Mr_Alexander, adamjmtz, krazyace38 and 4 others like this
#2 Guest_Megaroad_*
Posted 18 February 2013 - 02:03 PM
Posted 18 February 2013 - 02:27 PM
- zooyork0721 likes this
Posted 18 February 2013 - 02:53 PM
Posted 18 February 2013 - 03:12 PM
#7 Guest_Megaroad_*
Posted 18 February 2013 - 04:13 PM
By the way give a few mins to settle and use msm-dvcs gov and noop sched
Flashing now. What's msm-dvcs gov and noop sched and what do I do? I tried googling but it wasn't very illuminating for me.
Posted 18 February 2013 - 04:24 PM
a very efficient and wide range of Dynamic Clock and
Voltage Scaling (DCVS) which addresses usage models from
active standby to mid and high level processing requirements.
A Krait CPU can smoothly scale from low power, low
leakage mode to blazingly fast performance.
Posted 18 February 2013 - 07:12 PM
- gpost49 and smokestace like this
Posted 18 February 2013 - 07:20 PM
- adamjmtz, mr4r4n and zooyork0721 like this
Posted 19 February 2013 - 03:59 PM
#12 Guest_Xplorer4x4_*
Posted 20 February 2013 - 12:31 AM
in the market is no frills cpu control app, install it and here is the info on the gov
Would you please refrain from using the dark font. Many users use an inverted tapatalk or dark themed taptalk and it is impossible to read. FYI though you could use a single opening font and color tag at the start of the post and a single set of closing tags at the end rather then doing it every sentence/line.
Hope to get some time to check out this ROM tomorrow as I can't read over half of what is included. :-p
Posted 20 February 2013 - 03:44 AM
Posted 20 February 2013 - 04:57 AM
Safe strap only way to install or is it possible to flash via TWRP or CWM on Dev Edition?
FYI I've found any ROM that says SafeStrap only will in fact flash to a Dev edition just fine. However I have not tested all the ROMs but all the ones I have do work just fine. It does take one extra step tho in some cases but i do it for any flashing just to be safe. When i first got my Dev HD most ROM flashing would fail if you didn't use SS.
That said if you are using TWRP on your Dev edition go into Mounts & manually check the "Mount System " box, then back out and flash the ROM and do any wiping you may need and you should be good to go. I don't use Clockwork recovery anymore so I'm not sure if it would work the same way or not but I'd assume it would.
Posted 20 February 2013 - 05:12 AM
Thank you. I have TWRP installed also.
Posted 20 February 2013 - 08:15 AM
Posted 21 February 2013 - 06:43 AM
Currently I have my Dev edition HD running AC!D with the Beats addon, and my Dev edition M I have AC!D running with the Nooz addon.
Posted 23 February 2013 - 01:35 PM
Sent from my perfect MAXX HD running MAXXIUMUS v2.2 HD
Posted 26 February 2013 - 07:56 AM
I tried flashing twice with a full wipe/factory reset in a Rom Slot in Safe Strap. Each time everything seems to be great except I can't get screen rotation even though the setting to rotate is checked. Flashed back to JB leak in the stock slot and the screen rotates fine.
Posted 27 February 2013 - 05:14 PM
