Twitter Facebook
[Theme] Red Edge For Stock 173
  • You cannot start a new topic
5 replies to this topic
#1 wulf
wulf
    Themer
  • 920 posts
  • Twitter:@Wulf_X1
  • LocationMidwest
Posted 27 February 2012 - 11:29 PM
Heres my Red Edge theme for Stock 173
  127.25K   26 downloads
  351.36K   34 downloads
  167.62K   26 downloads
  56.38K   21 downloads
  130.73K   18 downloads
  109.4K   11 downloads
  76.59K   10 downloads
  36.51K   7 downloads
Install Instructions:
Make sure you on stock173
(Recomended) Make a backup in recovery and reboot (always a good ideal before flashing anything) and have enough juice in case something goes wrong
Download the theme and place it on your sd-ext (not internal memory)
Reboot into recovery with Razr bootstrap
select choose zip from sd card and navigate to where theme is
select theme and confirm selection again.
When theme has finished installing go back and reboot
Enjoy!!!
I also made a revert to stock zip you can flash. You can use it to remove a theme for stock or if you have issues.
NOTE:If you lose settings for any reason flash the revert to stock zip, reboot then flash theme, should be good after that.
Red Edge for Stock 173 - no longer supported
Revert to Stock 173 - no longer supported
#2 Thach
Thach
    Trailer Park Astronaut
  • 1,785 posts
  • Twitter:thach2639
  • Google+:Thach26
  • LocationGrand Forks ND
  • Current Device(s):Droid Razr, Nexus 7, Droid Bionic
Posted 28 February 2012 - 06:30 AM
Damn, now I may go back to stock to check this out. I love red themes. Great job.
Blasted with my AOKP AXI0M[R]
#3 wulf
wulf
    Themer
  • 920 posts
  • Twitter:@Wulf_X1
  • LocationMidwest
Posted 28 February 2012 - 06:52 AM
Thanks.
#4 Rouger
Rouger
  • 55 posts
  • LocationLongmont, CO
Posted 28 February 2012 - 08:48 AM
Downloading now. Looks great. Love red themes...
Edit**
Looks great. Had to do the revert and reinstall for setting to work but not an issue.
Good job...
#5 wulf
wulf
    Themer
  • 920 posts
  • Twitter:@Wulf_X1
  • LocationMidwest
Posted 28 February 2012 - 11:52 AM
Edit**
Good job...
Good to here it. Thanks.
#6 shaggie821
shaggie821
  • 131 posts
Posted 16 April 2012 - 04:02 PM
Luvit!!! FYI Notification Toggles folds right in w red theme so i would assume it would work on all edge themes np. Only tested red edge.
  69.74K   11 downloads
  22.37K   8 downloads
