[Bootstrap] Safestrap For Cdma Razr [02/28: Version 1.09] [Bugfix]
recovery bootstrap
49 replies to this topic
#1 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
  • Twitter:Hashcode0f
Posted 28 February 2012 - 08:34 PM
SAFESTRAP 1.09 for CDMA RAZR (XT912) (2nd-System Bootstrap / Recovery)
[ After installation boot into recovery and make a FULL backup while in Non-Safe mode to have a full 1st and 2nd system backup for disaster recovery. ]
** INSERT STANDARD DISCLAIMER: I'm not responsible for any damage you do to your phone using my tools. **
[ Make sure you get the RAZR version ]
[2012-02-28 UPDATE]:
- [2012-02-28 10pm pst] Reposted w/ the correct version showing in the app.
- Fixed webtop restore so that it doesn't break the webtop's partition signature and send you to the fastboot screen on the next reboot.
Entry to recovery via Splashscreen on boot-up. The screen stays up for around 8-10 seconds and if you hit the menu button, it takes you to Safestrap Recovery.
SPECIAL THANKS TO:
  • Koush who develops such a GREAT recovery system and the makes the source available for others to use.
  • The Atrix dev team who I pulled the internal/external SD card support from
  • The Defy dev team that originally developed the Bootmenu source which I stripped down and used for the Splashscreen.
As always, let me know what you think!
Edited by DarkestSpawn, 13 March 2012 - 04:09 AM.
Fixed link to new blogs
#2 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 28 February 2012 - 08:37 PM
RESERVED FOR FUTURE USE
#3 (TSON)
(TSON)
  • 529 posts
Posted 28 February 2012 - 08:56 PM
App still says 1.08 :c
But thanks for the update!
#4 jumemoto
jumemoto
  • 6 posts
Posted 28 February 2012 - 09:31 PM
It does say 1.08 after installing but when I booted up into recovery it said I was running 1.09 so I'm not sure why it says that
#5 jumemoto
jumemoto
  • 6 posts
Posted 28 February 2012 - 09:45 PM
When I try to boot after toogling into safe mode it wont boot up only shows a blank screen.. what do I do?? anyone else having this problem?
edit: I had to toggle back into nonsafe mode to get the phone to boot up.. am I just impatient and need to wait longer for it to boot?
#6 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 28 February 2012 - 10:02 PM
Fixed the version #. You can re-download and install so that the version check works correctly. Don't need to reinstall the recovery.
#7 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Which ROM is giving you this issue?
#8 jumemoto
jumemoto
  • 6 posts
Posted 28 February 2012 - 10:06 PM
I'm still on the stock rom. I just rooted and then installed safestrap that's it. I saw another guy had the same problem he posted on the blog
#9 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 28 February 2012 - 10:18 PM
Did you install a ROM while in Safe mode? You'll need to flash something before it'll boot.
#10 jumemoto
jumemoto
  • 6 posts
Posted 28 February 2012 - 10:32 PM
Oh no I didn't ok I see so basically there is nothing on the 2nd part and i just need to flash a rom to it? That makes a lot of sense lol
#11 phaim
phaim
  • 19 posts
  • Twitter:phaim11
Posted 28 February 2012 - 10:35 PM
Hey Hashcode, thanks for the great work. I have a question for you (please forgive me if someone's already asked this). Is it possible to have the 1st and 2nd systems save to the external SD Card instead of the Internal emmc? Unfortunately Google Music's stashing all the music I save for offline use (stupid subways) on the Internal emmc and it's causing a serious space shortage for me. Of course, if you had any ideas about how to force Google Music to post offline music to the external SD Card that'd work fine too!
Thanks man
#12 got556
got556
  • 452 posts
  • Twitter:@got556
  • LocationChicago
Posted 28 February 2012 - 10:58 PM
w00t w00t! Thanks Hash, you're a great asset to this community!
#13 Agoofydiver
Agoofydiver
  • 12 posts
Posted 28 February 2012 - 11:18 PM
For some reason it's not telling me that recovery is installed nor that I'm in safe mode even though it is for both. Rebooted into recovery says 1.09 and it backed up just fine. Any ideas?
#14 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 29 February 2012 - 12:01 AM
You could try redownloading the APK. I didn't have the version #'s correct (recovery was fine).
Thanks man
Yeah I see this as a current issue. All of the ICS ROMs use /sdcard as the default for storage. I'll see what I can find. The bad news is that the internal storage will be used even more in the 2.0 version of safestrap that I'm working on. It creates full image file systems which are mounted as /system and /data replacements. but the speed from the external SD card isn't reliable enough.
#15 mrhacks
mrhacks
  • 55 posts
  • LocationFlorida Keys
Posted 29 February 2012 - 04:12 AM
wOOt! Hash thanks for the update.
Do I need to uninstall v1.08 before I install v1.09 or will it install on top of previous version?
#16 nevildev
nevildev
  • 32 posts
Posted 29 February 2012 - 05:19 AM
Thanks for the update! I was on 1.08 and successfully updated from axiom rom... no need to uninstall and reinstall mrhacks
Sent from my AOKP AXI0M [R] using Tapatalk
#17 mrhacks
mrhacks
  • 55 posts
Posted 29 February 2012 - 05:32 AM
#18 brandonspell08
brandonspell08
  • 24 posts
  • Locationdallas, tx
Posted 29 February 2012 - 06:35 AM
Awsome hashcode.
Thanx for the wonderful program
#19 Agoofydiver
Agoofydiver
  • 12 posts
Posted 29 February 2012 - 07:23 AM
Tried downloading it a couple more times. It keeps doing the same thing. No big deal. I toggled between safe and unsafe modes just fine and everything is working. Just isn't saying it correctly in the Safestrap menu for me. I know it's installed and that safe mode is active.
#20 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 29 February 2012 - 11:11 AM
Sorry I was fail yesterday and missed the version #'s in the APK. I reposted the download file with that correction:
Also tagged with one or more of these keywords: recovery, bootstrap
