"failure [install_failed_VID_ changed]"
Check the attached picture. Help if you can!
file:///C:/Users/todd/AppData/Local/Temp/SaveForWeb/BrowserPreview/BrowserPreview_tmp.html
Posted 10 March 2013 - 06:41 AM
Posted 11 March 2013 - 11:43 AM
Posted 11 March 2013 - 03:09 PM
Posted 11 March 2013 - 03:26 PM
Posted 11 March 2013 - 04:49 PM
Posted 11 March 2013 - 04:58 PM
Chriswyn,
Can you post a screen shot of your "about phone" screen? That way we can see what build your sitting on, which will make it easier to find the correct utility to get you rooted. Then if we use the correct utility, and it still fails you'll have narrowed down the issue and troubleshooting will be a little more precise
Posted 11 March 2013 - 05:10 PM
Posted 11 March 2013 - 05:49 PM
Posted 11 March 2013 - 05:51 PM
Posted 11 March 2013 - 06:20 PM
Posted 11 March 2013 - 06:34 PM
Posted 11 March 2013 - 06:35 PM
Posted 11 March 2013 - 06:36 PM
Sorry I'm a little tired. What Page do I download root JB, with supersu?
Posted 13 March 2013 - 09:43 AM
Posted 20 March 2013 - 08:07 PM
Posted 23 March 2013 - 12:10 PM
make sure phone is in USB Debugging... and before you start do anything just double click on adb.exe it will bring a command promt for a sec load its self and you can than be sure you have adb connection.Cant get past the
*daemon started successfully*
HELP!!!
