Android Acronyms
16 replies to this topic
#1 SoLongSidekick
SoLongSidekick
    YOU WILL HAIL!
  • 687 posts
Posted 05 March 2012 - 01:53 PM
Good idea was brought up so I'm starting an acronym thread. I only had time to throw a couple in so post all of the ones I missed and I'll add them to the OP.
DR - DroidRzr.com
OP - Original Post
OEM - Original Equipment Manufacturer
VZW - Verizon
GSM - Global System for Mobile communications (cell band used worldwide)
EU - Europe
CDMA - Code Division Multiple Access (cell band used by Verizon in the US)
4G LTE - 4th Generation Long Term Evolution
RTb - ROM Toolbox
TiBu - Titanium Backup
ADB - Android Debug Bridge
LED - Light Emitting Diode
AMOLED - Active-Matrix Organic Light Emitting Diode
FC - Force Close
ROM - Remote Operations Manager
OC - Overclock
FBF - Fast Boot Files
Terminology
Kang - The act of taking a ROM built by someone and repackaging it as your own, with little to no credit to the original programmer.
ROM - Operating system (for lack of a better term) for your phone, most often referred to replacement operating systems.
Flash - Act of installing a ROM
Nandroid Backup - A backup of your original system, most often made before flashing a custom ROM in case something goes awry.
RSD Lite - Motorola tool used for returning your phone to stock.
Fast Boot Files - The files used by RSD Lite to return your phone to stock.
Overclocking - The act of boosting the speed of your phone above factory standard.
Odex - Standard file setup with .odex files that preload parts of applications on boot
De-odex - Combining two files or something like that so you can customize images and theme (Someone please give me a better description here)
  • got556 and In2Deep like this
:-D :-D
#2 In2Deep
In2Deep
  • 7 posts
Posted 05 March 2012 - 02:12 PM
Thanks for the thread! This will be great for newb's like myself :)
Here is a couple I noticed on the first thread I clicked
What are these?
eodexed
eu
Here is one I learned on the same thread I found those two on
FC - Forced Close
#3 SoLongSidekick
SoLongSidekick
    YOU WILL HAIL!
  • 687 posts
Posted 05 March 2012 - 02:30 PM
Updated with really bad descriptions of .odex and deodexing. Hopefully someone will step in with a better explanation.
:-D :-D
#4 JungleKing76
JungleKing76
  • 446 posts
Posted 05 March 2012 - 03:13 PM
Just wanted to add so some noobs don't get confused. While the term kang can be a negative as you pointed out where someone essentially uses others work with no credit, it is not always the case.
The new AOKP roms are from a dev team called team kang and they are certainly not taking others work. It simply refers to unofficial modified work.
#5 snives
snives
  • 947 posts
Posted 05 March 2012 - 03:18 PM
Just wanted to add so some moons don't get confused. While the term kang can be a negative as you pointed out where someone essentially uses others work with no credit, it is not always the case.
To be fair, most of the larger developers give fair credit for their kangs anyways. DHacker/DT are both great examples with how they plainly call the ICS ROMS CM9 or AOKP based.
#6 SoLongSidekick
SoLongSidekick
    YOU WILL HAIL!
  • 687 posts
Posted 05 March 2012 - 03:23 PM
Exactly, that's why the "without giving credit" qualifier is there. Look at any of DT's or DHacker's threads and they give gratuitous credit to the original devs.
:-D :-D
#7 snives
snives
  • 947 posts
Posted 05 March 2012 - 03:25 PM
ODEX/DEODEX is a long, but simple explanation.
ODEX stands for Optimized DEX
DEX stands for Dalvik Executable
Code compiled with ODEX consists of multiple files working together as a single program
De-ODEX is simply 'ODEX got removed', the same as debloating is to bloating. The De-ODEX process is done to make modifying code much more manageable.
With how you have it laid it, it might make more sense to have VZW = Verizon Wireless
#8 SoLongSidekick
SoLongSidekick
    YOU WILL HAIL!
  • 687 posts
Posted 05 March 2012 - 03:32 PM
HAHA I noticed that I did that, but I decided to leave it to see who it would bother and see who is OCD like me.
:-D :-D
#9 Thach
Thach
    Motorola Fanboy
  • 2,364 posts
  • Twitter:thach2639
  • Google+:Thach26
  • LocationGrand Forks ND
Posted 05 March 2012 - 03:52 PM
This is a great write up and I am sure it will help a lot of people out.
My RAZR Bleeds Awesomeness!!!!
#10 got556
got556
  • 452 posts
  • Twitter:@got556
  • LocationChicago
Posted 05 March 2012 - 03:59 PM
Great write up bro. Here's another one for ya.
OTA - Over The Air
ETA: and a few more...btw ETA stands for "Edited To Add"
ICS 4.0.X - Ice Cream Sandwich
HC 3.X - Honeycomb (only for Tablets)
GB 2.X - Gingerbread
CWM - Clockwork Mod Recovery
BS - Bootstrap
SS - Safestrap
BL - Bootloader
Gapps - Google Applications
#11 In2Deep
In2Deep
  • 7 posts
Posted 05 March 2012 - 05:30 PM
This is great! After reading your guy's posts I feel like there is a lightbulb going off over my head and I'm saying "oohhh, I get it now"
OTA, I was trying to figure that one out the other night :)
#12 scottysize
scottysize
  • 52 posts
  • Twitter:scottysize
  • Google+:scottysize
  • LocationSanger, TX
Posted 05 March 2012 - 05:46 PM
Here's a few more definitions as well as a few more acronyms.
ADK: Android Development Kit, What people use to develop anything for the droid such as ROM's
Boot Loader: State in which the droid can be flashed from RSD with an appropriate .sdk file that reprograms the phone into a specific ROM or update. This is typically a last resort when the recovery screen cannot be reached to make a much simpler and less risky solution
Boot Loop: simply means something is preventing the phone from completeting it's boot cycle and is stuck somewhere in the boot up process. This is often fixed by either reloading a Nandroid, or Reflashing a rom from the Boot Loader.
Brick or Bricked: Jargon for a completely unrecoverable device, (no more than a brick or paperweight)
Bug or Software Bug: an Error or flaw in software that produces a failure or enexpected/unwanted result.
Dev. or Developer: An individual that creates, or allters a file in such a manner as to advance the program
Kernel: The govenor of the CPU useage and Battery output, one can upload certain Kernals to achieve greater performance speed of their device at the cost of some battery life
Root: Common word associated with giving a user "super user" access to their phones programming and other various asspects that would normaly not be possible.
OS: Operating system, I.E. Windows Vista or MAC or ANDROID
ROM: The actual acronym in computer speak stands for Read Only Memory
Shell or SSH: secure shell or ssh is a network protocol that allows data to be exchanged using a secure channel between two networked devices
SPR or SPRecovery: A recovery program that is often used to apply updates, ROMs, or create a back up or restore a backup file
Stock: Simply means an un alltered state, such as when you first purchase your phone from verizon, or when you do a factory reset to "go back to stock 2.1"
SU: "Super user", or root permissions
Theme: A set of icons, backgrounds and app trays that change the ascthetics of the overall look of the droid and its applications
Underclocking: Slowing down the CPU mainly to limit battery usage
.sbf: Summation Briefcase File
.apk or APK's: An .apk file extension denotes an Android Package (APK) file, an .apk file can be opened and inspected using common archive tools
.tar: Similar to a zip file, a tar file archives multiple files into one file
.tgz: TGZ files are commonly used as install packages for Slackware Linux
RAZR No Longer.  Currently running the LG G2 and HTC One (M8)
Time for Moto to update the line!
#13 tkjross
tkjross
  • 13 posts
  • LocationClemson,South Carolina
Posted 07 March 2012 - 08:58 AM
I noticed it to but I went to my happy place so it wouldn't bother me.
#14 yedei
yedei
  • 36 posts
Posted 16 May 2012 - 07:14 PM
EU stands for European Union
#15 OlDirtyGrizzly
OlDirtyGrizzly
  • 143 posts
  • LocationNewburgh, NY
Posted 06 June 2012 - 04:51 PM
you forgot one
BAIAYS - Buy a iphone and your screwed
#16 Guest_BDH_*
Guest_BDH_*
Posted 06 June 2012 - 04:58 PM
Where I'm from, ETA means Estimated Time of Arrival.
Which is why Rule #1 is "Never ask for ETAs."
  • shobon and OlDirtyGrizzly like this
#17 benefit14snake
benefit14snake
  • 232 posts
Posted 08 June 2012 - 04:29 AM
Where I am from it means Edible Taco Arrangement.
Sent from my Axiom MAXX!!
