I can't flash a ROM to safe my life. Hold my hand.
Posted 14 March 2013 - 09:24 AM
The issue comes when I try to flash a rom. I go into safestrap and select a slot. I install my rom and go to boot the thing and it just loops over and over back into safestrap and the "M" logo. No rom takes and I can't figure out why...like at all. Even if I try to flash over the stock rom slot it just boots back into the stock JB. That is the only slot that does not boot loop. I'm kind of lost at this point and don't really have a clue as to what to do next. I'd love it if someone cold tell me what the next step is or let me know of a way to wifi tether as I was before with FoxFi. At this point I'm contemplating downgrading to ICS just to have my tethering back but I really like the features of JB and would like to keep it. If someone can save me on this, I'd very much appreciate it since even if I wanted to downgrade, I'd still have to flash an ICS rom which I can't seem to flash anything. Also, assuming I get this worked out if you can suggest a rom for me that'd be cool too.
Thanks fellas!
I've posted over at droidforums but no luck...
- dylan101 likes this
Posted 14 March 2013 - 09:42 AM
Sent from my DROID RAZR
Posted 14 March 2013 - 09:46 AM
Sent from my DROID RAZR using Xparent Skyblue Tapatalk 2
Posted 14 March 2013 - 10:09 AM
Make sure the Rom you're trying to install ids for the .16 or official OTA. If it's for .8 it will bootloop.
Can you please elaborate.....I am currently on the OTA JB update 4.1.2 The ROM I picked was jellyhaters I think. Can you suggest a rom that will work or kind of help me understand why it isn't working?
Posted 14 March 2013 - 10:15 AM
Posted 14 March 2013 - 10:21 AM
Look at post #3 above, those 2 ROMs are for your update that you are currently on (.16). ROMs that say "leak" are .8 which won't work for you. Hope this helps.
Sent from my RAZR Maxx
Posted 14 March 2013 - 10:30 AM
Updated: Flying Jelly, Cyclone, Aviator, Rage and CM10.1 not sure if any others have been updated yet....
Posted 14 March 2013 - 10:45 AM
On CM10.1....I can't seem to find the one for the Razr, am I missing something here? I feel like such a tool after being out of the game for almost a year of not messing with this phone I come back and there's all this new stuff I never caught on to.
Does anyone happen to know of a way to wifi tether on stock JB by chance?
Posted 14 March 2013 - 11:26 AM
Very cool guys, thanks for the help! I will give it a shot when I get home.
Make sure you are getting the ROMs from the right page:
Also, some ROM's, such as Aviator, have the wifi entitlement hack built into them. If they do not then you can always do it yourself. I don't have a link handy but google "droid razr wifi entitlement hack". Basically you will use SQL lite to change a value in settings.db.
Posted 14 March 2013 - 11:38 AM
Sent from my Droid Razr Maxx on JB 4.2.2 kexec
Posted 14 March 2013 - 04:58 PM
You guys are the coolest....everything is working great. I am tethering as we speak. I went with the CM10.x but it's a little buggy and slow. Will probably switch over to Aviator.
Posted 30 March 2013 - 07:04 AM
