Droid Razr won't screen rotate
Posted 27 March 2013 - 01:28 PM
#2 Guest_BDH_*
Posted 27 March 2013 - 07:21 PM
I have a droid razr and can't get screen to rotate. Please help.
If you're using the stock JB launcher, go to System Settings>Display and make sure "Auto-rotate screen" has a check box.
The launcher itself will not rotate though. You would have to edit framework-res.apk to enable that by decompiling the apk then going to res>values then open the "bools.xml" file to enable screen rotation.
- Twiztedhippie66 likes this
Posted 27 March 2013 - 11:55 PM
Posted 28 March 2013 - 03:35 PM
Posted 28 March 2013 - 04:02 PM
Posted 29 March 2013 - 12:30 AM
Or if you want the stock home app to rotate... you could take the easy way out....
I just want apps to auto rotate I don't care if the home screen rotates. I tried the app above and it won't work.
That program makes ANYTHING and EVERYTHING on the phone rotate. Sounds like you have auto-rotate disabled in the phone's accessibility menu. If so.... it will override the program.
Posted 29 March 2013 - 12:35 AM
I got one of those accelerometer apps and they didn't show anything. What does this mean?
Be hard to say without knowing what program you used. Probably means nothing.
Posted 12 August 2013 - 09:18 AM
After a year and half of having my razr, i was having no problems till i got the recent software update. Got a replacement "like new phone" still having touble thought, because my home screen wouldnt rotate, but apps would. I downloaded this app and now its working again.. THANK YOU!!!
Posted 27 December 2013 - 11:42 AM
