Twitter Facebook
Question On How To Get Visual Voicemail
  • You cannot start a new topic
8 replies to this topic
#1 mkeefner
mkeefner
  • 7 posts
  • Twitter:keefner21
  • Google+:mkeefner
Posted 26 March 2012 - 04:26 PM
As the topic states how do I go about getting the stock Verizon vvm on a razor running an IcS from?
Sent from my DROIDRAZR using Tapatalk
#2 superrelaxx
superrelaxx
  • 853 posts
  • Twitter:jasNwa
  • LocationSeattle, Washington
Posted 26 March 2012 - 04:37 PM
To date, this is not going to happen. Configure Google Voice and you're good to go. An excellent alternative.
#3 snives
snives
  • 927 posts
Posted 26 March 2012 - 05:02 PM
Google Voice is free, easy to setup, and not dependent on carrier (if you ever change, Google Voice can go with you). I personally think Verizon's Visual Voicemail is pointless with an Android device. Also, if/when we get unlocked bootloaders, it is safe to expect that the community will start drifting away from basing ROMs on pure Verizon kernels, which in turn means Verizon services become less and less useful to the modder.
#4 mkeefner
mkeefner
  • 7 posts
  • Twitter:keefner21
  • Google+:mkeefner
Posted 26 March 2012 - 05:05 PM
I have tried to set up Google voice. Having issues. But I have only tried from my phone ill try setting it up on my computer.
#5 snives
snives
  • 927 posts
Posted 26 March 2012 - 05:10 PM
What setup steps have you done?
1) Get an account if you don't have one
2) Install Google Voice app
3) Set Google Voice as default voicemail on phone (will say you need to do manual setup)
4) Enter all 3 forwarding codes (like dialing a phone call)
I can find the forwarding codes for you if you are having a hard time
Edit>
Here are the activation codes, borrowed from this thread
  • *71[Your Google Voice number]
  • *90[Your Google Voice number]
  • *92[Your Google Voice number]
If you ever wish to discontinue using GV, you need to dial the disable numbers
One number is for missed calls, one for ignored calls, and the third for line busy I believe, but I can't remember in which order.
#6 mkeefner
mkeefner
  • 7 posts
  • Twitter:keefner21
  • Google+:mkeefner
Posted 26 March 2012 - 07:25 PM
I got it set up. I had to get online and activate it. Its set up now. Thank you for your help
#7 Moonkai
Moonkai
  • 9 posts
Posted 10 April 2012 - 07:04 PM
Not entirely sure I understand the question correctly, but if you want visual voicemail on ICS it's there and works fine.
I have it on mine right now using the ICS build from moto.
When it installs it replaces the voicemail link on the home screen with the standard dial-in VM link.
The VVM link is under apps.
Again, I apologize if I'm missing the point of the question.
EDIT: Didn't see the date, sorry. This section of the forum must not be all that active, this post was only like 6 down from the top.
#8 mikeymax
mikeymax
  • 80 posts
Posted 10 April 2012 - 08:06 PM
Yeah I use visual voicemail on the leak everyday.....
#9 _base2
_base2
  • 830 posts
Posted 10 April 2012 - 09:49 PM
Google Voice ftw!! Beats the shiznit outta visual voicemail. Web access, transcription, ability to retrieve deleted messages... the list is quite long on the things that GV does buy VVM doesn't.
[ sent from _base2 ]
