TWRP Themes
timpohladthomas
, Apr 11 2013 07:57 AM
5 replies to this topic
Posted 12 April 2013 - 03:20 PM
ive been flashing a bunch of them. they all flash but i cant find one for the m's screen size. if you find one in a root browser go to sdcard/twrp create a folder in twrp called theme all lower case. then change the name of the zip to ui.zip and paste it in the theme folder you created and just reboot into recovery and it will flash
i found one that works i believe it the resolution that matters. the resolution is 480*800 i flashed the light one no problem
sig made by
Rinkle McBally
Posted 02 April 2014 - 06:20 PM
This thread is no longer officially supported, please see newer officials topics is applicable
