Anyone else seeing this in their TWRP Mount Menu???:
Device: Droid RAZR Maxx HD with Unlocked Bootloader using Rooted Stock 4.1.2
I have been hopping around to see if anybody else has been having this issue without much success. Who I have talked to see what
posted
(notice the additional Mount System & Modem options minus the Mount USB Storage button). CWM Recovery shows System & Modem as Mount/Unmount options but not TWRP. Anyone up to helping me on this or troubleshooting with me?
Update:
So, I knew this was most likely a simple issue but I didn't know HOW simple it really was. First, I figured it was probably a System img issue because my OTA update reported as failed but still showed 4.1.2/9.16.6.XT926.Verizon.en.US. I think what that was is that I may have still had some apps disabled and/or frozen and possibly the fact that I had a different boot animation. Regardless, I reflashed 4.1.2 using
's
and everything seems to be much smoother. Not only was TWRP displaying properly but I was simply able to restore Data and be back to where I left off since I made a complete backup. This actually isn't the issue that causes this. It is TWRP Themes that were causing this. Not really paying attention I started with
and didn't realize that they're for Galaxy Nexus (but still 720x1280). The next ones that I tried are BigDaddyHicks'
. These were causing the same display issues. However, I did notice that
's
did in fact work but not entirely. In the Mount Menu Mount/Unmount Modem was still missing (didn't really look elsewhere for differences). Problem solved, I guess.
