Presents:
Original Jelly Bean Fastboot Files for DROID RAZR M Verizon
Android 4.1.2 ---- 98.15.66.XT907.Verizon.en.US
VZW_XT907_4.1.2-9.8.1Q-66_1FF.xml.zipp
Firmware DROID RAZR M Verizon Jelly Bean 4.1.2 by "Firmware Team"
Posted 25 April 2013 - 03:30 AM
- neckchop and hillmom like this
Firmware Team: Kent_lkc - Kwachu - daywalker04 - Pzyduck - Skrilax_CZ - toto221
Posted 25 April 2013 - 04:43 AM
good job, I hope it's a fastboot flashing way, I don't like the RSD way.
Posted 25 April 2013 - 06:12 AM
Posted 17 May 2013 - 08:16 PM
thanks for this. had to use it to get my phone back to 99% stock. Since I deleted apps and deleted the actual app data with it, i couldnt use matts util (my fault)
Posted 18 May 2013 - 11:02 AM
how can i flash this file in my device and i m from Pakistan.after update it my sim card network is available on it or not?
Posted 08 November 2013 - 09:33 AM
Holy crap you just saved my life... well made my day/week.
Thanks!!!
Posted 14 November 2013 - 11:42 AM
I bricked my M, i have all the drivers, RSD v6.1.4 I was running a 4.3 rom when i bricked,unlocked bootloader. I've tried to flash every fastboot file for the m and everyone of them fail. any ideas on what to do I'm stuck
Posted 14 November 2013 - 12:52 PM
attached is a picture of failed flashing
Posted 14 November 2013 - 12:56 PM
Posted 15 November 2013 - 05:32 AM
i've tried every firmware for the razr m that is available they all fail some in different places
Posted 15 November 2013 - 05:34 AM
Posted 15 November 2013 - 05:44 AM
\VZW_XT907_4.1.1-9.8.1Q-27-2-4_1FF.xm
Posted 15 November 2013 - 05:49 AM
Posted 15 November 2013 - 05:51 AM
thanks for your help, downloading now i'll let you know what happens
Posted 15 November 2013 - 06:13 AM
i give up!
Posted 15 November 2013 - 06:28 AM
If you are unlocked you are safe to flash this one without losing the ability to root.
WARNING TO OTHERS- DON'T FLASH THIS IF YOU ARE ON A LOCKED BOOTLOADER IF UOU WANT ROOT. Sent From My DEV X
i give up!
OK first of all... you said you are bricked because??? if your phone comes on but stuck in boot log or boot animation it is not bricked... fact is if you can turn phone on it isnt bricked
your phone is probably failing because some or most of software in there isn't original
having that said, if you are unlocked and and can somehow get to fastboot which i see you can. flash
and flash another ROM I recomendThat should get your phone back into working order
and if you are unlocked you probably most likely wont ever need to flash the original motosoftwear. just TWRP for it all...
Posted 15 November 2013 - 06:29 AM
wow, not sure what happen, was trying to cut the phone completely off so i could save the battery until i had the patience to deal with it, and some how it booted into cwm, i had tried to boot into recovery yesterday and it just kept giving me the little dead android, flashed a rom and gapps and the damn thing booted up working fine.
Posted 15 November 2013 - 06:35 AM
Glad to read that...
