XT926 Powers on into Fastboot
Best Answer johnthehillbilly , 11 May 2013 - 12:46 PM
My XT296 is rooted and unlocked and when I power down my phone and power it back on it goes into fastboot and I have to hold vol up & down and power button to get it to boot up. I tried to flash twrp and got a fastboot flash failure. Now my phone will not power up like it did before flashing twrp and getting a fastboot flash failure. How can this be fixed?
My best recommendation would be to use Matt's utility .... http://www.droidrzr....ux/#entry272317 .... :)
tapadriving...... hillbilly style Go to the full post
15 replies to this topic
#1 puttfordoe
puttfordoe
  • 10 posts
  • LocationNor Cal
  • Current Device(s):Rzr Maxx HD
Posted 11 May 2013 - 12:25 PM
#2 johnthehillbilly
Posted 11 May 2013 - 12:46 PM   Best Answer
#3 puttfordoe
puttfordoe
  • 10 posts
  • LocationNor Cal
Posted 11 May 2013 - 01:12 PM
so the only way to fix this fastboot flash failure is to flash stock 4.1.2, then reroot and reflash twrp?
#4 johnthehillbilly
Posted 11 May 2013 - 01:22 PM
There may be another, easier, way but I don't know it...... I will admit I'm not as up to speed on flashing twrp as maybe I should be but ..... most flash failures are easily fixed with the utility ..... :)
Unless it is a "low battery flash failure"
#5 livinginkaos
Posted 11 May 2013 - 03:20 PM
When it boots into fb, does it state a reason in the Lower left? If you had part of a flash fail on something non critical it may still boot on bptools
#6 johnthehillbilly
Posted 11 May 2013 - 04:32 PM
Indeed :)
#7 puttfordoe
puttfordoe
  • 10 posts
  • LocationNor Cal
Posted 18 May 2013 - 08:52 PM
Yes, it says fastboot reason: flash failure. I have tried to use Matt's utility and flash back to stock 4.1.2 it won't work. In fastboot it says USB connected but when I try to run option 1 it does nothing but flash a cursor. The script never starts.
#8 johnthehillbilly
Posted 18 May 2013 - 08:59 PM
Do you have all the current drivers installed on your computer?..... is your battery low? (That will most certainly cause flash failure)...... you said it never starts..... does it just close?.... or does it sit on "waiting for device"?
Are you using windows or Linux script?
  • shane1 likes this
#9 puttfordoe
puttfordoe
  • 10 posts
  • LocationNor Cal
Posted 19 May 2013 - 06:28 AM
I have the current drivers installed and my battery is 100% and I am running XP
#10 johnthehillbilly
Posted 19 May 2013 - 06:33 AM
Do you have access to windows 7? Or Linux ?...... I know it may sound trite but occasionally / unfortunately the utilities don't play well on XP
#11 puttfordoe
puttfordoe
  • 10 posts
  • LocationNor Cal
Posted 19 May 2013 - 07:18 AM
Do you have access to windows 7? Or Linux ?...... I know it may sound trite but occasionally / unfortunately the utilities don't play well on XP tapadriving...... hillbilly style
No, but I will have access to windows 8 as soon as my new computer arrives.
#12 puttfordoe
puttfordoe
  • 10 posts
  • LocationNor Cal
Posted 19 May 2013 - 07:26 AM
I got twrp installed off the utiily using XP.
#13 puttfordoe
puttfordoe
  • 10 posts
  • LocationNor Cal
Posted 29 May 2013 - 07:53 PM
Does the Droid Razr HD utility 1.20 work with Windows 8? I am trying to use option 1 to restore my phone and when my phone is in AP fastboot with usb debugging on and my phone connected to the computer I get a 'fastboot' is not recognized as an internal or external command, operable program or batch file error when I hit enter. I installed the Windows 64bit drivers. What could be causing this error?
#14 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 29 May 2013 - 08:43 PM
Most people have been having issues with 8.
#15 johnthehillbilly
Posted 29 May 2013 - 08:47 PM
Also...... make sure you fully extracted the utility to desktop...... when you run the .bat file ..... right click and run as administrator .......
Reminder: use 2.0 USB port....... 3.0 does not play nice with our RAZRs sometimes
tapadriving.....hillbilly style
#16 nine5raptor
nine5raptor
  • 371 posts
  • LocationMO
  • Current Device(s):Droid Bionic, Droid Razr M, Nexus 5, Moto X
Posted 01 June 2013 - 12:15 PM
Also try different cable (factory only) and turn off all virus protection software - key for me. Try a different USB port.
Sent from my Red Swingline Stapler
