drm protected content storage making cpu% run high and makes phone hot
8 replies to this topic
#1 kadeas
kadeas
  • 5 posts
  • Locationshelby, oh
  • Current Device(s):droid razr xt912
Posted 12 May 2013 - 02:18 PM
Hi new here and have my first problem. I have a droid RAZR xt912 and I noticed recently the phone running really hot, up to 109° and that's in a cool climate. The CPU is running around 80 to 90 %. I have since stopped drmprotectedcontent and it dropped temp and CPU back down to normal. Now my question is is it OK to disable this app, what is this app? I also have a folder that says Music on my phone not on SD, and it says 1 file but when I open it it does nothing and when I try to delete it it just keeps adding files to be deleted and never starts to delete. Its been up to 20000 files before and I finally just cancelled the delete. Make since? Thanks in advance !
#2 Guest_BDH_*
Guest_BDH_*
Posted 12 May 2013 - 02:24 PM
That's some weird stuff going on.....
Have you tried completely restoring the phone yet?
#3 kadeas
kadeas
  • 5 posts
Posted 12 May 2013 - 02:30 PM
No I haven't. I guess if I don't find a solution soon that will be my only option.
#4 Guest_BDH_*
Guest_BDH_*
Posted 12 May 2013 - 02:34 PM
Hate to say it but it sounds like your only option.
You can use Matt's RAZR Utility though to get you back to stock Jellybean.
#5 kadeas
kadeas
  • 5 posts
Posted 12 May 2013 - 06:42 PM
OK thank
#6 johnthehillbilly
Posted 12 May 2013 - 06:50 PM
tapadriving...... hillbilly style
#7 johnthehillbilly
Posted 12 May 2013 - 06:51 PM
Droid RAZR Utility
INDEED!!:)
#8 kadeas
kadeas
  • 5 posts
Posted 13 May 2013 - 02:55 PM
Well I got the music folder deleted finally. I had to plug it into my comp. and delete it from there. So far no problems. I'll give it a day or two and see what happens. Thanks guys!
#9 kadeas
kadeas
  • 5 posts
Posted 13 May 2013 - 02:57 PM
