[Mod]Droid Razr Ics Leak - Deodexer
Posted 22 April 2012 - 01:43 PM
- Disclaimer
DroidRzr.com, myself, or any other party CANNOT be held responsible for what you decide to do. Modifying system files can lead to a damaged or comletely bricked device!!! Your phone! Your choice! Your responsibility!!!!
- Installation
Note: This is a Deodexer Droid Razr on the 6.14.75 ICS leak! You must be on the leak to use this MOD!!!!
Download file and place on SDCard. If you do not have a backup, now is the time! Install from SD like normal. Allow to finish then reboot, the first boot may take some time.
*This has only been tested with Credits To DHacker for Bootstrap for Razr ICS!
- Credits
Google - For the Android we play with.
Motorola - For fantastic hardware!
Nitroglycerin33 - for a few tips when I was stuck!!!
- Download
MD5: 3becd4626eacbca09009ea0e56653d68
Moto-Razr-ICS-6.14.75-Deodexer -
*DO NOT FLASH IF YOU HAVE FLASHED DT'S MOD FOR THE ICS-LEAK*
I personally tested and confirmed you would have to do a full restore!
- Support Me
Though I don't require it by any means... its always nice! So if you'd like buy me a beer! --->
-Noted Issues
-The issues with the Gallery sync after speaking with nitroclycerin33 is almost a pipe dream to fix! lol. I will replace with the AOSP gallery when I get time to patch the camera properly.
- For those that wish to use DockService... DockService.apk is deodexed I just some how forgot DockService.odex in the /system/app directory which will cause conflict and for some random FC's. There are two simple solutions until I have time to update. The first would be to use a root explorer with /system mounted as RW... and delete /system/app/DockService.odex. The second option would be to modify the Deodexer zip to remove the odex and reflash. A Reboot will be required afterwards but it will fix the issue!
- mattlgroff, JBeXX, cynnar and 5 others like this
Posted 22 April 2012 - 01:45 PM
Sent from my Razr Maxx using Tapatalk
Posted 22 April 2012 - 01:48 PM
Posted 22 April 2012 - 02:08 PM
and does this mean there will be a 1% mod too?
Edited by leviwg, 22 April 2012 - 02:09 PM.
Posted 22 April 2012 - 02:09 PM
Posted 22 April 2012 - 02:11 PM
sorry, my clock on my computer and on here are about an hour off.It wasn't posted a couple of hours ago.. lol. but the link is live now!
Posted 22 April 2012 - 02:12 PM
Posted 22 April 2012 - 03:24 PM
Posted 22 April 2012 - 03:35 PM
Posted 22 April 2012 - 03:36 PM
Shouldn't need to. It completely wipes /system/app and /system/framework then installs the deodexed version. I personally didn't do a data wipe.
not even delvek cache
Posted 22 April 2012 - 03:40 PM
Posted 22 April 2012 - 03:41 PM
if you're like I typically am... It can't hurt!!! but I didn't wipe a thing. just flashed!
Thanks dude
Posted 22 April 2012 - 04:00 PM
Sent from my DROID RAZR using Tapatalk 2 Beta-6
Posted 22 April 2012 - 05:06 PM
Posted 22 April 2012 - 05:17 PM
At least 70% of the issues the support team (which is 90% Vanten haha) deals with is because someone didn't wipe the caches and then wonders what could have possibly gone wrong.
That should be second nature if you are flashing things.
- lownslow200sx likes this
:-D :-D
Posted 22 April 2012 - 05:21 PM
Posted 22 April 2012 - 05:29 PM
Posted 22 April 2012 - 05:38 PM
