[Mod] Accurate Battery [1%] Razr - Ics Leak.
34 replies to this topic
#1 EmericanX
EmericanX
    Developer
  • 1,027 posts
  • Twitter:@EmericanX
  • LocationPrince George, VA
Posted 25 April 2012 - 04:33 PM
Ok folks... Those of you that have been waiting for it... here it is! lol.. Accurate battery MOD for the Droid Razr ICS leak[system version: 6.14.75] I was going to include this in a project I'm working on but there was enough interest I figured I'd throw it out there for use.
- Disclaimer
DroidRzr.com, myself, or any other party CANNOT be held responsible for what you decide to do. Modifying system files can lead to a damaged or comletely bricked device!!! Your phone! Your choice! Your responsibility!!!!
- Installation
Note: This is only tested on a Deodexed ICS Leak for the Razr! You must be Deodexed to use this MOD!!!!
Download file and place on SDCard. If you do not have a backup, now is the time! Install from SD like normal. Allow to finish then reboot, the first boot may take some time.
*This has only been tested with
Credits To DHacker for Bootstrap for Razr ICS!
- Credits
Google - For the Android we play with.
Motorola - For fantastic hardware!
GunnerMike53 - Cant leave him out! Awesome server space!!!! Thanks Mike!
- Support Me
Though I don't require it by any means... its always nice! So if you'd like buy me a beer! --->
-ScreenShots and Downloads
Accurate Stock Battery
Download -
Accurate Stubby Battery
Download -
Accurate Round Battery
Download -
  • SoLongSidekick, ralphie0108, cynnar and 8 others like this
#2 EmericanX
EmericanX
    Developer
  • 1,027 posts
mine... just incase!
  • SoLongSidekick and ralphie0108 like this
#3 leviwg
leviwg
    News Writer
  • 563 posts
Posted 25 April 2012 - 04:44 PM
you have a voicemail
a what? an android? whats that?
#4 theonlycosmic
theonlycosmic
  • 470 posts
  • LocationCalifornia
Posted 25 April 2012 - 04:49 PM
YESSS!!! MY OCD IS CURED! lol Great job, I can't wait for your "project." ;)
#5 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 25 April 2012 - 04:56 PM
LOL... thanks man! Glad I could help the OCD issue..
  • SoLongSidekick and theonlycosmic like this
#6 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 25 April 2012 - 05:02 PM
oh btw... voicemail? lol
  • SoLongSidekick likes this
#7 Guest_BDH_*
Guest_BDH_*
Posted 25 April 2012 - 05:05 PM
Hate to say it but I might have to leave Black Widow and go back to the leak now lol. Thanks for this!
  • EmericanX likes this
#8 leviwg
leviwg
    News Writer
  • 563 posts
Your screenshot has a voicemail notification.
  • theonlycosmic and EmericanX like this
#9 ralphie0108
ralphie0108
  • 64 posts
  • LocationTampa, FL
Posted 25 April 2012 - 05:06 PM
Done and done! Thanks X you're the man!
#10 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 25 April 2012 - 05:19 PM
LOL.. No problem man!
#11 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 25 April 2012 - 05:20 PM
Haha... I've always got voicemail! those that know me know to never leave a voice mail! they just text me.. lol
#12 SoLongSidekick
SoLongSidekick
    YOU WILL HAIL!
  • 687 posts
Posted 25 April 2012 - 06:15 PM
Awesome work man! And just for not whoring out the 'like' button, take some likes on all these posts. :D
:-D :-D
#13 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 25 April 2012 - 06:45 PM
lol... anytime man!
#14 kaplac
kaplac
  • 102 posts
Posted 25 April 2012 - 09:30 PM
This is great!
Definitely made ICS leak about x2 better with this
#15 Guest_BDH_*
Guest_BDH_*
Posted 25 April 2012 - 09:48 PM
Worked like a charm bro! Downloaded the Stock battery icon one (not stubby) and it's perfect! Just made the leak about a million times better!
#16 fbm111
fbm111
  • 56 posts
  • Twitter:fbm111
Posted 25 April 2012 - 10:38 PM
I am on stock leak. Does that mean I am deodexed or not?
#17 kaplac
kaplac
  • 102 posts
Posted 25 April 2012 - 10:44 PM
fbm111: Check out the link below. If you haven't run the mod on the OP of that thread then you aren't deodexed yet and this mod won't work
#18 theonlycosmic
theonlycosmic
  • 470 posts
Posted 25 April 2012 - 11:53 PM
Ok so I just finally got everything working and flashed the gummy stub battery one. Now I have no notification bar. I have internets and everything, but just no bar to see anything. I tried wiping cache dalvik and batt stats and flashed then went back into cwm to try and flash again but no go. I had it working at first but then I deleted a system app and got a million fc so I reboot and its gone. I put the app back in yet still no notification bar. Yes I changed permissions. Any help?
Edit: oh and I also have no wallpaper. Even if I set it to sumtin it no show.
#19 leviwg
leviwg
    News Writer
  • 563 posts
Posted 26 April 2012 - 02:03 AM
This happened to me with something else. Your going to need to do a restore from before you flashed. You must be on the stock ics leak, rooted, and then install the deoxed mod from emericanX. Then you can flash this too. So double check all of those before you flash this.
#20 theonlycosmic
theonlycosmic
  • 470 posts
Posted 26 April 2012 - 05:25 AM
So there is no way to move around any apks?
