I'm trying to install the ICS leak through that app which we don't speak of but in order to check for updates i have to sign in with my motocast id. When i try to do that it wont load. If i go through settings and then go to accounts and i try to sign in a loading bar pops up for less than a second and then it tells me there's an error and that it is unable to load. I can login fine from my computer though. Does anyone know how to fix this?
Motocast Unable To Load
jaegs21
, Apr 28 2012 03:58 PM
ICS motocast unable load error update updates
2 replies to this topic
Posted 28 April 2012 - 03:58 PM
- jaegs21 likes this
Posted 28 April 2012 - 04:22 PM
When in the unspeakable app, the window that pops up along about signing in, don't sign in. Just hit set up, it will by pass this and you are good to go.
Posted 28 April 2012 - 06:43 PM
That worked but I have to install the .181 update and that keeps failing to load. I think i will just flash a custom rom for now and then get the official ICS when it is released in a month. Thanks for the help though
Also tagged with one or more of these keywords: ICS, motocast, unable, load, error, update, updates
