* * * * * 1 votes
Droid Razr M won't root
Droid M Root Android fail Root fail Root error
Best Answer ulk768 , 13 June 2013 - 08:58 PM
Okay, success. Thanks rikrong and shane1. Doing a factory reboot and keep running the script til it works.
Go to the full post
15 replies to this topic
#1 ulk768
ulk768
  • 8 posts
  • LocationMontana
  • Current Device(s):Droid M
Posted 13 June 2013 - 04:43 PM
Hi guys first time here. I first found this group while looking up directions on rooting my Droid Razr M. I used motochopper and clicked on run. Everything went through with my phone rebooting at the end. I've made sure my drivers were installed. Rootchecker says that I'm not rooted after reboot. Also, superuser app says the same things, any suggestions? Oh I've tried to root using the other root files from Rosenberg but that didn't work either.
Any more things I could try? Maybe step by step directions to make sure I'm not missing anything.
Thanks.
#2 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 13 June 2013 - 08:13 PM
Not much help tonight cause I'm falling asleep, but when I rooted my M I had to run the script a few times then it worked.if not I moved to RAZR M general cause you should get more help here ! Goodluck
  • ulk768 likes this
sig made by
Rinkle McBally
#3 ulk768
ulk768
  • 8 posts
  • LocationMontana
Posted 13 June 2013 - 08:18 PM
Yea, I've ran the script at least 5 times- no luck. I'll try again a couple times tonight. Anybody else have any other suggestions?
#4 RikRong
RikRong
    Cap'n Slow
  • 2,116 posts
  • Twitter:@rlongjr80
  • Current Device(s):Moto X Pure 2015 / N7 2013 / RazrM
Posted 13 June 2013 - 08:21 PM
The first time I rooted my phone, it had already been completely set up.  The root wouldn't take, so I had to wipe cache/dalvik and FDR to get the exploit to work.  The second time I rooted was after FXZ'ing back to stock.  I ran the root exploit immediately after activation and prior to completing setup.  It worked with no hitch.  I'm not sure why this happens on this phone.  I didn't have to wipe my table to root it.
  • shane1 likes this
R. Long: Nexus 5 on Carbon / Slimmed N7 2013 / RazrM stock KK
#5 ulk768
ulk768
  • 8 posts
  • LocationMontana
Posted 13 June 2013 - 08:27 PM
Okay  Wiping cache/dalvik FDR and FXZ'ing back to stock. I have no idea what that is but I'll google those instructions and let you know what happened. Thanks.
#6 RikRong
RikRong
    Cap'n Slow
  • 2,116 posts
Posted 13 June 2013 - 08:32 PM
Whoa whoa whoa, don't FXZ (fastboot) back to stock yet (sorry about the confusion). There's no need for that. You only need that if you've borked your phone. Try wiping caches, first. If that doesn't work, then FDR (factory data reset) and wipe caches. Wiping should get the exploit to work.
I had to fastboot my phone because I soft bricked it, and it had to be re-rooted after that. I just did it immediately and didn't have to wipe anything.
  • shane1 likes this
#7 ulk768
ulk768
  • 8 posts
  • LocationMontana
Posted 13 June 2013 - 08:35 PM
Gotcha, thanks. I'll wipe the cache and do a FDR. Thanks for clarifying that up for me.
#8 RikRong
RikRong
    Cap'n Slow
  • 2,116 posts
Posted 13 June 2013 - 08:39 PM
I apologize for not being clear in my first post.  I just didn't want you to reset the phone if you didn't need to.  FDR will do pretty much the same thing, but there are other variables that could go wrong if you've never fastbooted or are not comfortable with it.
#9 ulk768
ulk768
  • 8 posts
  • LocationMontana
Posted 13 June 2013 - 08:55 PM
Okay after doing a FDR still a no go, I'll keep trying.
#10 ulk768
ulk768
  • 8 posts
  • LocationMontana
Posted 13 June 2013 - 08:58 PM   Best Answer
  • neckchop, livinginkaos, RikRong and 1 other like this
#11 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 14 June 2013 - 01:40 AM
Now make sure to do lots of reading before you do anything!
  • RikRong likes this
sig made by
Rinkle McBally
#12 public_anemone
public_anemone
  • Current Device(s):Motorola Droid Razr M, Motorola Droid X, Motorola Droid 2 R2D2
Posted 18 July 2013 - 11:33 PM
I just stumbled upon this discussion. I have the exact same problem and no matter how many times I try, I can't seem to root my Razr M. What exactly did you guys do? I used the same methods. FDR then used motochopper multiple times but it just wont work.
#13 RikRong
RikRong
    Cap'n Slow
  • 2,116 posts
Posted 18 July 2013 - 11:36 PM
He just kept running the exploit, until root worked.  A couple details, though.  Are you on the latest update?  Do you have an unlocked bootloader?  What have you done to try to root, so far?
#14 public_anemone
public_anemone
Posted 18 July 2013 - 11:38 PM
I am on the latest update. No to unlocked bootloader. And I have tried motofail2go and doomlord exploits.
#15 RikRong
RikRong
    Cap'n Slow
  • 2,116 posts
Posted 18 July 2013 - 11:45 PM
They locked up the root exploit with the latest update. Motofail is for 4.1.1, Motochopper is for 4.1.2 (pre-update). If you had an unlocked bootloader, you would be able to re-root, but if you're not unlocked, you're out of luck for now. There are rumors that people were rooting the update with Motochopper, but I don't think that was ever proven.
#16 public_anemone
public_anemone
Posted 18 July 2013 - 11:48 PM
Damn, I guess I'll just wait and hope for a new exploit or just keep trying. Well, thanks anyway
Also tagged with one or more of these keywords: Droid M, Root, Android, fail, Root fail, Root error
