Wifi Issues On Leak
Posted 18 May 2012 - 09:54 AM
Posted 18 May 2012 - 10:35 AM
Did it work previously and has stopped working or is this a fresh flash? If it's a fresh flash, I'd say start over. I haven't personally had any issues with wifi on these leaks.
If it was working and has just started messing up, you can try a hard reset and/or a data, cache and dalvik wipe and see if it helps.
Also, this should have probably been posted in the help forum instead of the development section.
Posted 18 May 2012 - 11:51 AM
Posted 18 May 2012 - 12:22 PM
It's not a good idea to restore ICS apps and data back to GB. Backing them up and then reapplying the leak shouldn't be a problem though. Try the hard reset and wiping cache and dalvik if you don't want to wipe data, but I'm guessing you just got a bad flash and the wifi radio is not setup properly. You could also try reflashing the leak in stock recovery. Haven't tried that but it might work. Would recommend re-downloading the leak though in case your copy was corrupt.Sorry for the wrong section. I am on. 75 . I did not try wifi until today. But on gb I know it worked. I would like to avoid a data wipe if possible. But if not I guess I'll go ahead. Question: if i backup apps and settings on the leak and then restore on GB will that be a problem?
Posted 18 May 2012 - 12:29 PM
Any ideas? Background: I was on 75, Matt's 1.51 back to 173>181>root & Voodoo>85>lost root>terminal>root again.
Posted 18 May 2012 - 12:30 PM
Posted 18 May 2012 - 12:34 PM
So, I'm Hotel California'd on 85, but I've been having wifi issues since 75. Wifi drops out-gray bars instead of blue, sometimes it'll go back to blue but I still have to toggle wifi to get an internet connection again.
I have the same issue on .84. Under the wifi settings its saying "connecting, conntecting,disconnecting" and rapidly cycles over and over the same thing. But when I go home on my router there is fine. Only my work routers are doing this.
If you can, I'd verify that the AP's your trying to connect to have the latest firmware installed. I haven't been on .84 or .85, but both .75 and .79 haven't given me any wifi connection issues to speak of.
Posted 18 May 2012 - 01:44 PM
Care to elaborate on AP's? Is that the same as a router? Also didn't mention I did not have this issue on 173, wasn't on 181 more than 5 minutes so not sure about that one.
Posted 18 May 2012 - 01:51 PM
Yeah, AP = access point or router in this case. I know what you mean about it working on 173. I have an ipad that worked fine until I upgraded it. Then it wouldn't keep a connection to my home router. Worked fine on the one at work. Once I upgraded the firmware on the home router, everything went back to normal. There is still some fluff in the 802.x specs for wifi so each peice of hardware can be a little bit different.Care to elaborate on AP's? Is that the same as a router? Also didn't mention I did not have this issue on 173, wasn't on 181 more than 5 minutes so not sure about that one.
Posted 18 May 2012 - 02:19 PM
How do I do a hard reset?It's not a good idea to restore ICS apps and data back to GB. Backing them up and then reapplying the leak shouldn't be a problem though. Try the hard reset and wiping cache and dalvik if you don't want to wipe data, but I'm guessing you just got a bad flash and the wifi radio is not setup properly. You could also try reflashing the leak in stock recovery. Haven't tried that but it might work. Would recommend re-downloading the leak though in case your copy was corrupt.
- G8orDroid likes this
Posted 18 May 2012 - 02:20 PM
Sounds like a plan. Soon as I get home or maybe in the am (not sure how late the wife's gonna keep me out) I'll check the firmware.
Posted 18 May 2012 - 04:44 PM
Posted 18 May 2012 - 04:47 PM
Full shutdown from main power menu or press and hold power and volume down for about 10 seconds.
Posted 19 May 2012 - 01:56 PM
It's an older Netgear modem that never had isses before 84. Not ready to blame the router just yet.
Posted 19 May 2012 - 03:31 PM
Did you read my other post? It's not a question of whether to blame the router or not. My router worked fine with every other phone, PC, Wii, DirecTV receiver, etc. in my house, but when I upgraded my iPad it had problems. Upgrading the firmware on the router fixed my problem. While it may not fix yours, I can't see what it would hurt.It's an older Netgear modem that never had isses before 84. Not ready to blame the router just yet.
Posted 19 May 2012 - 03:41 PM
Yea, I saw that. But these are old Netgear 614's at work. Can't really change/update them. :/Did you read my other post? It's not a question of whether to blame the router or not. My router worked fine with every other phone, PC, Wii, DirecTV receiver, etc. in my house, but when I upgraded my iPad it had problems. Upgrading the firmware on the router fixed my problem. While it may not fix yours, I can't see what it would hurt.
Posted 19 May 2012 - 03:46 PM
Edit: I also forgot to mention that my wife's Razr on 181 has no issues with the wifi.
Posted 19 May 2012 - 09:33 PM
#19 Guest_BDH_*
Posted 20 May 2012 - 03:00 AM
I had issues when I was on the .75 leak with the mobile hotspot. When it times out for inactivity, it would not turn off, but get frozen. It would not turn off or back on at all. I couldn't even force stop the system app.
To stop that from happening go to System Settings > then press on the word "Wifi" not the toggle. Press the Menu button and select "Advanced." The change "Keep Wifi On During Sleep" to "Never." Then when your phone goes to sleep it will automatically shut off wifi then re-enable it when the phone is woke up.
Posted 20 May 2012 - 05:02 AM
Thanks. I'm on the .79 leak now. Lost root and couln't restore when I was on .75. I just got the hotspot hack woking again today, so I will give that a try.
