I don't know how else to describe it. It dies like the batterys dead but its not I thought it was a hardware issue with the battery because it only dose it when its NOT plugger in to the charger but it works fine in boot loader mode or recovery so it has to be side ware related. It started after I stated mod the setting apk and systemui apk with ninjamorph. But I'm kinda confused how I caused this just by swapping out .PNG images. Dose anyone know what I did?
system crash?!?!
Posted 13 July 2013 - 07:21 PM
Posted 14 July 2013 - 01:38 AM
Posted 14 July 2013 - 03:25 AM
I think if anything it was the system ui because issues didn't start until I changed that. But how did simply swapping out and image file do this? And why dose it work fine when its plugged in but dies and crashes at boot when not?
I'd really like to figure this out so I can keep my edits and still Have something that works
Posted 14 July 2013 - 03:37 AM
There are pretty much two possibilities why it dies when you unplug it.... either the software "thinks" the battery is dead or its just bad timing and your battery has gone bad......
If you power off and plug into a wall charger.... do you get the charging screen?
... telekinectically tapping, tenaciously traversing the terrain...
Posted 14 July 2013 - 03:43 AM
Posted 14 July 2013 - 01:52 PM
Yes I get the charging screen and I tried that utility and it didn't work still bootloops and rsdlite flashing stock didn't work either rite now I'm trying red again after the fail with the utillity. Idk if it still works plugged in or not
Oh yes I had backups and they failed to fix it also
Posted 14 July 2013 - 01:55 PM
- neckchop likes this
Posted 14 July 2013 - 02:17 PM
att this point i cant get to recovery stock or twrp, ill trypulling the sd card any idea how i can wipe internal storage from fastboot? everything else just puts me back into the boot loop
Posted 14 July 2013 - 02:30 PM
This sucks. I am currently charging in fastboot cuz otherwise it just boots and dies boots and dies......
Posted 14 July 2013 - 02:42 PM
It dose. Had to do it for previous issue. But rsdlite fixed that.
Posted 14 July 2013 - 02:45 PM
Posted 14 July 2013 - 03:02 PM
I wondered about flashing a ROM as a fix my self but I'm kinda new to this how do I do this w/o getting to recovery I've only flashed Roms from safestrap and twrp
Posted 14 July 2013 - 03:13 PM
Thanks. Keep me posted
Posted 14 July 2013 - 07:14 PM
Maybe someone smarter than I can jump in here and provide some more insight ....
Posted 15 July 2013 - 06:39 AM
I think I might have gotten recovery back. The phone completely died and when I plugged it in again I was able to boot in to twrp recovery. Because the battery was so low it died again shortly after and I didn't wanna leave it charge last night when sleeping or when I'm at work now so ima plug it back in when I get home and see what I can do
