Build prop edit to get data and SMS/MMS working on XT926 4.2.2 ROMs
Posted 01 August 2013 - 09:13 PM
Do at your own risk, worked for me but I'm not responsible for your crack flashing, build prop editing, up all night modding your phone till your wife leaves you, rear end. With that said here ya go.....
Edit build props to reflect this :
ro.carrier= T-Mobile (or your carrier)
ro.telephony.default_network = 9
telephony.rilV7NeedCDMALTEPhone = false
That's it. Don't reboot between each line you edit just edit all three lines then reboot and profit.
Sent from my XT926 unlocked running Illusion 4.2.2 on T-Mobile . So F#@& Verizon...
- adamjmtz and tarheelbandb like this
Posted 13 September 2013 - 06:43 PM
Posted 19 September 2013 - 11:16 PM
If you're unlocked and rooted and have done like I have and gave Verizon the middle finger and used the radiocom unlock tool to open up the potential to use such networks as T-Mobile, Straight talk , ATT, Net10, or Sprint prepaid. You may have encountered the same problem I have and loaded some of these bad rear end ROMs these talented devs have built for us and our XT926 Verizon RAZR HD/HD MAXX. After getting tired of going back to 4.1.2 over and over due to lack of SMS/MMS and data on 4.2.2 I started diving into the build props and found a few to edit to obtain SMS/MMS and data.
this isnt working for me please help
Posted 19 September 2013 - 11:18 PM
on my xt926 ,after the edit i am getting very poor service with at&t and text messaging isnt working at all?any suggestions would be appreciative...thanks again
