So I recently flashed ICS 6.14.79 onto my Razr Maxx and was trying to install safestrap so i can play with ROM's and such. I install safestrap.apk, then click the app icon in my drawer adn install recovery. Once I rebooot I get the option on splash screen to tap menu for recovery. I can get into recovery, I can make a backup of my system before switching to safemode and everything works just fine. I can reboot my system at this point and it will boot up fine. I can either wait the 10 seconds or I can hit search and it will boot.
But if I go through the safe menu and enable safeboot or safemode or whatever its called... my phone will NOT boot. it will get to the splash screen, and if i wait it goes to a black screen and goes NO FURTHER. the only way I can get it to boot is to hold the power and volume up and down keys for about 20 seconds ad my screen will flash, then I can hold just the power and it will reboot and I can go back into recovery and un do the safemode and it will boot.
I made sure I am using (or trying to use) 2.0, I have never installed bootstrap, this was a fresh loaded phone, razr utility 1.6 to load .181, then combo ics installer 0.3 to install ics 6.14.79. Rooted with teh ics installer which used the motofail exploit, loaded my apps and tried to flash the BEATS update...
Help please?
