trouble unlocking bootloader
17 replies to this topic
#1 gautama
gautama
Posted 11 August 2013 - 05:30 PM
I've got a xt907 running 98.15.66 with safestrap installed. I had been running eclipse but would now like to unlock the bootloader and install better recovery/newer ROMs.
I'm in the stock slot and I have root, yet when I run the motopocalypse app it does not unlock the bootloader. What gives?
#2 Someolddude
Someolddude
  • 426 posts
Posted 11 August 2013 - 08:30 PM
Did you go into boot loader and check of it says locked or unlocked? Did you install the latest drivers and did the computer see your phone? Gotta be something simple if I figured it out.
#3 wem97
wem97
  • 18 posts
  • Google+:WEM97
  • LocationSeattle
  • Current Device(s):Motorola Droid Razr HD
Posted 12 August 2013 - 06:13 AM
Im sailing in the same boat here. I hate to break it to ya, but motorola fixed the security hole that allowed us to unlock the bootloader :/ I cant unlock mine either for the same reason. As far as I know they havent fixed it yet. At least this is so with my HD.
#4 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 12 August 2013 - 08:58 AM
Did you accept the update, then revert back?
He's not showing on the latest update, he should be able to unlock.
#5 gautama
gautama
Posted 12 August 2013 - 11:57 AM
Yeah I reverted back. I guess I'm stuck then :/
#6 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 12 August 2013 - 12:12 PM
Yeah, that sucks.  Thanks Moto and Verizon.;)  If you updated, it patched the exploit, and reverting it back still won't allow you to unlock.  However, you can still root it.
#7 gautama
gautama
Posted 12 August 2013 - 03:56 PM
Are there any ROMs still being updated that don't require an unlocked bootloader? It seems like most new development has moved on.
#8 wem97
wem97
  • 18 posts
  • Google+:WEM97
  • LocationSeattle
Posted 12 August 2013 - 08:43 PM
Im not sure. Im kindve compiling myself a list of them. I would do that and check all the latest activity reports on the threads ;)
#9 allmightywest
allmightywest
Posted 15 August 2013 - 11:41 AM
I'm new to the forums and been following the locked bootloader issue. I have a dev. Droid Razr M - model XT907.
Motorola will unlock the bootloader of this model.
I think if you buy a phone, you should be able to do with it as you wish. Hope maybe this helps with the OTA fix.
#10 icaro96
icaro96
  • 5 posts
Posted 23 December 2013 - 02:12 PM
Yeah, that sucks.  Thanks Moto and Verizon. ;)  If you updated, it patched the exploit, and reverting it back still won't allow you to unlock.  However, you can still root it.
i'm the same situation i accidentally update to 98.18.79 w/no unlock bootloader... now i downgrade to 98.15.66 but any program failed unlocking bootloader, yes root...
...any news to unlock bootloader?!?!?
#11 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 23 December 2013 - 05:04 PM
Since you already updated to .79 and then downgraded, you can't unlock the BL.  .79 locked up the Trusted Zone and reverting won't re-open it.  No, there's no news on a new unlock and there probably won't be.
  • Memnoch73 and icaro96 like this
#12 icaro96
icaro96
  • 5 posts
Posted 26 December 2013 - 08:07 AM
Thanks for replay, suspected this...
anyway if only the root is fine with me; can't put the custom rom, but at least can use correctly the applications apk...
good work
#13 bgoode2006
bgoode2006
  • LocationUSA
  • Current Device(s):Droid Incredible, HTC Rezound, Droid 4
Posted 03 January 2014 - 08:11 PM
i am on 98.15.66 and the only thing i have downgraded is the modem. i have never been on anything above this system version yet i still cannot unlock with either the app or the program
#14 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 03 January 2014 - 08:22 PM
If you're on that system version, you should be able to unlock.  Can you boot into your AP Fastboot screen and tell us what the date is?
#15 rootedgranny64
rootedgranny64
  • 25 posts
  • Current Device(s):droid bionic xt875
Posted 06 February 2014 - 07:35 PM
5/24/2013 is mine can I unlock it
#16 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 06 February 2014 - 07:40 PM
No, unfortunately that's the version they locked up the bootloader.
#17 rootedgranny64
rootedgranny64
  • 25 posts
Posted 06 February 2014 - 07:42 PM
K if I use voodoo ota keeper can I upgrade and keep root??
#18 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 07 February 2014 - 09:46 AM
There's a method to root that version and the latest OTA.
