Can I dirty flash the new build or should I do a full wipe?
Source has been updated no major changes just some build enhancements and navbar menu is working should dirty flash fine
Posted 06 October 2013 - 12:24 PM
For those unaware and I forgot to mention instead of unlockable developer settings they were replaced by performance settingsSent from my XT907 using Tapatalk 2
Proud father of a US Marine
Posted 06 October 2013 - 01:27 PM
Posted 06 October 2013 - 01:29 PM
Ehh I see reply already, forgot to refresh page
wussup with the startup animation? Lok gave creeps to my gf
Posted 06 October 2013 - 06:30 PM
Posted 07 October 2013 - 10:38 AM
Now I'm having issues with MMS. I have confirmed/corrected APN settings but no change. In fact, when using the APN settings
the APN I am editing disappears. There appear to be quite a few additional APNs in the list that should not be there...
Any advice?
Posted 07 October 2013 - 11:28 AM
Roll back to the 9/29 build? Luckily it is still on my SD.
*EDIT* MMS working fine on 9/29 build.
Posted 13 October 2013 - 10:07 AM
Motorola Razr HD Maxx
Root and Unlocked Bootloader | Blurry 1.2 HD | Nova Launcher | CrossBreeder MOD
Posted 13 October 2013 - 03:16 PM
OP updated
10/13
Cleaned up the interface
Took out Active Display till I can get some bugs worked out
Compiled with SaberMod Linaro 4.7
No Custom Kernel try it you'll see why
Builds will be a lil Slower with updates taking my time with this one
New Bootanimation (designed by RinkleMcbally and JaeKar99)
Builds for other devices are coming soon thanks and enjoy
Recommend clean flash
Not the same rom your used too but its my baby
Donations Not Necessary but tia
Posted 13 October 2013 - 06:26 PM
Anyone know if that mms bug is resolved? Really wanna get back on this rom but need that function
Posted 13 October 2013 - 06:36 PM
All I needed to know, thank you bud!
Posted 14 October 2013 - 09:04 AM
mms is still borked on my end and it won't allow me to save any apn changes to try and troubleshoot. otherwise solide build man! that boot animation is amazing haha
Posted 14 October 2013 - 05:14 PM
Posted 14 October 2013 - 05:18 PM
Posted 14 October 2013 - 05:43 PM
Posted 15 October 2013 - 04:37 AM
No luck with the Verizon app. My apns may be jacked up from messing with them and when I tap restore to default, they are staying the way I changed them. I will do a fresh dl and give it another go
