Twrp 2.6.3.0 has been working for me and its 4.3 friendly. Got a link here that flashes in recovery.
btw i appreciate your help and kindness in helping me solve this
Posted 09 October 2013 - 01:03 PM
61ZM(0)
Posted 09 October 2013 - 01:58 PM
That's what we're all here for man... I remember helping Someolddude when he was a young buck. Now I see him all over this place helping others. Pay it forward my friends.
Posted 09 October 2013 - 04:54 PM
ive never had this issue until 4.3 4.3 doesn't play nice with my phone
Honestly, it might be something in your install methods. I've noticed you have had problems on other ROMs too. Are you mounting sytem, before you wipe? I wasn't doing it and I had serious issues with 4.3. I started doing it and I've had no issues, other than ones directly associated with the ROM.
Somber, just a quick question. For some reason, my phone refuses to go to a lock screen. I've checked through settings and can't seem to find anything that would be stopping it. I've turned off the screen and let it sit for a while, but it will still not go to the lockscreen. I'm not sure if I'm missing something obvious. Other than that, this is working perfectly.
Posted 09 October 2013 - 04:59 PM
Are you using the stock messaging?? I had this issue with CM10.2. In the messenger settings there is something about auto unlock when message comes in. This worked fine for a but then eventually it would never lock. May not be your issue but thought I would throw it out there
Posted 09 October 2013 - 05:05 PM
Hmm, yeah I am using the stock app. I'll have to look at those settings. I didn't even think about that. Thanks.
Posted 09 October 2013 - 10:38 PM
61ZM(0)
Posted 09 October 2013 - 11:00 PM
No worries, sorry, I hope I didn't seem like I was lecturing you. The whole mounting thing has been around for a while, actually since the SafeStrap and early bootloader unlock days. However, it was kind of forgotten about when the newer versions of TWRP came out. Someone posted about mounting the system prior to wiping and installing a 4.3 ROM and they had no issues. I have also had no issues since I've started mounting system (again) before wiping. I'm not 100% sure why or how it works, I'm sure someone that is more knowledgeable will chime in. Mounting system seems to actually clear out data. Since you're not mouting prior to wipes, there may be some data left behind that is conflicting and causing the screen freezes.
Posted 10 October 2013 - 02:02 AM
Most of the flash scripts will do that work for you now so mounting would for the most part be unneededNo worries, sorry, I hope I didn't seem like I was lecturing you. The whole mounting thing has been around for a while, actually since the SafeStrap and early bootloader unlock days. However, it was kind of forgotten about when the newer versions of TWRP came out. Someone posted about mounting the system prior to wiping and installing a 4.3 ROM and they had no issues. I have also had no issues since I've started mounting system (again) before wiping. I'm not 100% sure why or how it works, I'm sure someone that is more knowledgeable will chime in. Mounting system seems to actually clear out data. Since you're not mouting prior to wipes, there may be some data left behind that is conflicting and causing the screen freezes.
Donations Not Necessary but tia
Posted 10 October 2013 - 04:07 AM
Somber, please - change name of bootanimation file on ROM.
Now it called bootanimation-alt and we have simple android animation.
When rename bootanimation-alt to bootanimation we have DU-bootanimation...
P.S. Sorry for my English
Posted 10 October 2013 - 03:40 PM
Posted 10 October 2013 - 08:05 PM
Flashed yesterday - nice work!But it have not PIE-control yet,,,
you can flash pie control separate. get it from
for the time being.
all other that have questions about Gapps, any 4.3 Gapps should work fine there are some slimmed down pack out there that would just do the bare minimal.
any bug this rom has it is AOKP bug than need to be iron out, you will run into the same problem if you run a CM10.2 rom that is why they are still in beta or un-official state. :
We all should be glad we have few Devs working on getting as many roms as we have.
Other issue i have seen is many of you guys are running CWM instead of TWRP. i will strongly recommend TWRP first because it is touch screen and second because it is what most of us Devs use to try our Roms out and cant really help you with a problem we are not having. :
As always happy modding and im sorry I may sound a bit rude but its only way you guys pay attention.
Posted 10 October 2013 - 10:10 PM
61ZM(0)
Posted 10 October 2013 - 10:27 PM
okay guys gave it one last try using twrp and still get the same thing no response figured since it showed it was updating my apps it was working i mounted sys each time i wiped data cache and dalvik and upon installation stil no f%$king response from my touch this ROM doesn't like my phone this is so f%$king irritating that its doing this ive tried everything and it still f%$ks up and i don't get why all the other ones are wipe flash and prosper whys all the 4.3 roms bust my phone as in not respond to my f%$king touch f%$k u 4.3 and Ur inability to work on my phone
61ZM(0)
Posted 10 October 2013 - 11:33 PM
Posted 10 October 2013 - 11:34 PM
Posted 10 October 2013 - 11:36 PM
Your not wiping system?
Sent from my Razr M using Tapatalk 2
Hmm, that sounds like the key here....
Posted 10 October 2013 - 11:57 PM
Posted 11 October 2013 - 03:04 AM
i came to find out... i had few issues as well but mine were keyboard related... when you coming form anything that is not android 4.3 you MUST wipe data as well as in you better save your stuff in your comp before doing anything or lose it kind of wipe. than everything flashed fine. i dont know if there is some mounting data conflict of something but that the way the cookie seem to crumble. im going to give a step by step should solve most of the issues i seen in this thread so far.
I wont argue that all Devs should post at least a link of one of the Gapps to save some of the confusion and help the new people, not everyone know where to find things and they need to be held by their hands until they learn. we were once noobs too.
Posted 11 October 2013 - 09:27 AM
Posted 11 October 2013 - 02:14 PM
