I've tried many 4.3 Roms however they all lag. It'll glitch with screen locking animation, while scrolling in the app drawer, using the keyboard, etc. I'm using CWM Recovery with no kernel tweaks. Any ideas?
4.3 Custom ROMs lag
Posted 24 October 2013 - 11:58 AM
- romma1 likes this
Posted 24 October 2013 - 04:09 PM
Well, let's see. What are the "many" roms you've tried? And is your bootloader unlocked?
- RikRong likes this
Posted 24 October 2013 - 04:20 PM
Posted 24 October 2013 - 05:52 PM
What kind of glitching are you talking about? Did you run clean installs? Second what Tucs asked? I'm running 4.3 on my M and HD and don't have any "glitches."
- neckchop and tucstwo like this
Posted 25 October 2013 - 02:56 PM
Hello core 2...
Hope all is well...Now, 4.3 does not Lag for me at All matter of Fact its quite Zippy...Is that a Word...
This is what I have "Under The Hood" of my Phone...this is for Performance
- Using SetCPU App
- Jack for Performance with the following settings
- Min is set at 800
- Max is set at 1200
- Governor-Hotplug
- Scheduler-Deadline
- Cache Cleaner NG
- Plus One Click Cleaner just for Sheets an Giggles
How fast...
I could Kick your rear end in a 440 Sprint...With Love... but Im too Fat...but the mind said i could so I will go with that... :
"All Good Under The Hood"...
Chow
- neckchop and RikRong like this
Posted 26 October 2013 - 05:21 AM
Posted 26 October 2013 - 09:35 AM
Hello core 2...
How fast...
- Using SetCPU App
- Min is set at 800
- Governor-Hotplug
- Cache Cleaner NG
Chow
What kernel / ROM are you using?
I'm experiencing a lot of stutter between apps and screens on the latest CM 10.2 nightly.
Using TWRP 2.5. With complete wipes between flashes.
Posted 26 October 2013 - 10:17 AM
Bad download or ReflashWhat kernel / ROM are you using?
Its Bubba
Posted 26 October 2013 - 10:36 AM
- neckchop likes this
Posted 26 October 2013 - 11:14 AM
I've never Mounted...I didn't mount System before wiping. I wonder if that's part of the problem
Its Bubba
Posted 26 October 2013 - 03:40 PM
you don't have to mount system most flashing scripts do that for you. The only thing you need to do is a factory reset then flash ROM then gapps.I've never Mounted...
Its Bubba
- The Persuader and Rob626 like this
Donations Not Necessary but tia
Posted 26 October 2013 - 03:55 PM
Iyou don't have to mount system most flashing scripts do that for you. The only thing you need to do is a factory reset then flash ROM then gapps.
Know Prior post was asking
Its Bubba
~Stubborn In Your Bones~
Posted 26 October 2013 - 04:24 PM
First off, disable system animations, it helps out a lot. Second, update to the latest TWRP. Third, a lot of people have found that mounting system prior to your wipes helps a lot. If you don't mount before wiping, it seems to leave data behind.
- neckchop and Rob626 like this
Posted 26 October 2013 - 05:41 PM
So If I am understanding this correctly...You have to Mount the System too...Thought Factory/System Cleared All the Excessive Data left behind...
So the process now is:
- Wipe Cache
- Wipe Data
- Wipe Factory
- Wipe System and Now
- Mount the System too...
Just asking...Never had any of what you mentioned Above with Data Conflict after I Wiping System...
Posted 26 October 2013 - 06:06 PM
So If I am understanding this correctly...You have to Mount the System too...Thought System Cleared All the Excessive Data left behind...
- Wipe Cache
- Wipe Data
- Wipe Factory
I go about it this way:
- FDR or the first main wipe option you get in TWRP
- Mount-->System
- Advanced wipe--> wipe cache/dalvik, system, data. When I go to a brand new ROM, I format data too.
Before I started mouting prior to wiping, I would have serious issues with 4.3. Now, they run flawlessly (I'm sure that's also due to the fact that they have been developed further and are running better).
- somber73 and Rob626 like this
Posted 26 October 2013 - 06:18 PM
- Mount-->System
This is exactly how I have been doing it, and all is smooth sailing. In addition, I always turn off the animations in developer options.
- Rob626 likes this
Posted 26 October 2013 - 07:24 PM
Posted 26 October 2013 - 07:25 PM
Hmm, that's weird, I haven't had an issue with FB.
Posted 26 October 2013 - 07:27 PM
