Here's a new battery mod that I created that is unique and easy to view.
Disclaimer
Standard disclaimer.
Installation
Note: This has been tested on The Arctic, Eclipse and the deodexed .2XX base from Kebob. To be used with RAZRSafestrap-ICS-2.00.
You must be Deodexed to use this MOD!!!!
Make a Nandroid before applying. It's a good practice in case something goes wrong or you decide you want to revert back.
Download file and place on SDCard. Install from SD. No need to wipe anything.
EDIT: I'm recreating the mods to be used specific to the rom installed. If it's not listed and you'd like to use it on your .2XX based rom, shoot me a PM and I'll update for you.
Credits
EmericanX for the script and the tips.
spc_hicks09 for the APKTOOL tutorial to get me started.
Screenshots
- 99-31% solid blue
- 30-11% solid yellow
- 10-0% solid red
- Charging and 100% are solid green.
- 99-31% gradient white/blue
- 30-11% gradient white/yellow
- 10-0% gradient white/red
- 99-31% solid blue
- 10-0% solid red
Links:
HTC Sense Battery Mod
Arctic:
Bionx Nx
Simplex V1.2
Gradient Battery Mod
Arctic:
Eclipse:
Eclipse (with stock 3G/4G icons)
Black Widow ICS:
Stock 211 Deodexed by Kebob:
Stock 215 Deodexed by Kebob:
Solid Battery Mod
Arctic:
Arctic (extra large):
ArcticHD (extra large):
Eclipse:
Eclipse (stock 3G/4G icons):
Eclipse-v1.2 (extra large):
Black Widow ICS:
Stock 215 Deodexed by Kebob (extra large):
If you would like learn how this is done, you'll need a few things.
- The tools necessary to decompile and compile the SystemUI.apk. Check out this link provided by spc_hicks09:
- From your desired ROM, grab SystemUI.apk from system/app/ and framework-res.apk from system/framework and copy the files to your computer. From here, follow the directions from the link in step 1.
- Once you've decompiled the SystemUI.apk from your desired ROM, locate the new SystemUI folder and naviagate to: SystemUI/res/drawable-hdpi. The battery discharge icons are labeled as: stat_sys_battery_[number here represents battery reading] and stat_sys_battery_charge_anim[number here represents battery reading].
- The xml files associated with these images are located in the folder: SystemUI/res/drawable/stat_sys_battery and stat_sys_battery_charge. I had to change these xml files as I created a battery mod to represent accurate battery readings as opposed to jumping from 10% increments.
Silverlink34 mentioned he is going to create a full tutorial on this so I don't want to go in much more detail and take away from what he is working on.
Feel free to PM me with any questions I have. The way I learned was trial and error. And of course asking many questions
Edited by superrelaxx, 22 September 2012 - 12:32 PM.
