[ROM][XT907][Unofficial][4.3][AOKP]{DEPRECATED}
rom aokp xt907
17 replies to this topic
#1 tucstwo
  • Google+:tucstwo@gmail.com
Posted 07 November 2013 - 04:46 PM
Requirements:
Be Bootloader unlocked
Must be rooted!
Must be on TWRP/CWM recovery!
What works?
You flash and tell me!
Are there bugs?
Changelog:
Can be found
Thanks (in no particular order):
timpohladthomas
somber73
dhacker29
Hashcode
Downloads:
Last Builds MD5:
b69586e453c9d6d7195d59f435fa1b1e
4.3 GApps:
#2 Someolddude
Someolddude
  • 426 posts
Posted 07 November 2013 - 08:14 PM
Link to ROM seems to be down or it could just be on my end.
#3 kendog
kendog
  • 234 posts
  • LocationMillville, NJ
  • Current Device(s):droid bionic
Posted 07 November 2013 - 08:15 PM
It's working fine now. For some reason devs was slow as hell earlier.
#4 joules
joules
  • 5 posts
  • LocationMelbourne
  • Current Device(s):xt905
Posted 07 November 2013 - 08:40 PM
Thanks. I've looked at the previous so called GSM fix/patch and all it was a few changes to build.prop and a (now outdated) apns-conf.xml.
So its not needed and doing a diff doesn't really show much.
I have an xt905 there arent many differences with the xt907 (apart from the LTE freq@700), I don't have LTE(4G) anyway..so..
xt905:
GSM 850/900/1800/1900, UMTS 850/900/1900/2100, LTE 1800/2600 - Market dependent
xt907
CDMA 800/1900, GSM 850/900/1800/1900, UMTS 850/900/1900/2100, LTE 700
I haven't checked this build but the previous sbuild (10/30) only showed the verizon APN's and I couldn't delete or edit them.
But you can select Celluar networks (GSM).
Is this build built straight up with only CDMA support? Is it possible to create a buid that supports both CDMA and GSM (if it doesn't already)? Thinking that the CM 10.1 build worked with the GSM Fix, I can't see why not. But for starters the default verizon APN's setup when you select a country other than the US is a problem.
Give me some pointers and I can't work on hacking the configs in this build - Because I'm thinking its rather trivial.
Thanks.
Joules.
(I'm a programmer/developer by trade but have a job and have very little time and on weekends - sorry)
#5 Diversion
Diversion
  • 5 posts
  • LocationSt. Augustine, Florida
  • Current Device(s):Razr M (Verizon) and Galaxy Note 2 (Verizon)
Posted 08 November 2013 - 03:51 AM
I got no signal on my Verizon Razr M after flashing..
#6 joules
joules
  • 5 posts
  • LocationMelbourne
Posted 08 November 2013 - 04:03 AM
Try the 10/10 build
Thats the earlest version that at least gives me something. Also check if you can import SIM contacts (this build can't read my SIM).
#7 ejass
ejass
  • 37 posts
  • LocationIndonesia
  • Current Device(s):Droid Razr M XT907
Posted 08 November 2013 - 07:46 PM
just flash and I got "Unfortunately Android Keyboard has Stopped"
for netx buid can Nav Bar set Enable as a default n also other stuff from dirty unicorn :)
#8 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 15 November 2013 - 02:21 PM
Flashed this yesterday, seems like a really good rom but wifi won't turn on. Just says turning on but never does, waited 5 minutes. Got 3g and 4g/lte is working though. Have to agree with ejass about enabling Nav bar by default.
Need Help? Send me a message
#9 tucstwo
Posted 19 November 2013 - 06:32 PM
Updated tonight, sorry for the delay guys :)
#10 XIII
XIII
Posted 20 November 2013 - 02:00 PM
Has there been an update on the issues mentioned in this thread?  Both this build and the one posted on xda-developers would get force closes on AOSP keyboard and the wireless would not be able to identify any networks (much less connect to them).
I also lost mobile service (no calls, texts, or data) and my IMEI/baseband version/ would be labeled as unknown, although there's a reasonable chance this was caused by careless file deletion on my part when making space on my external SD card.  This issue probably would have existed regardless of what ROM I flashed, although I didn't check.  I had to RSDLite back to stock, re-root, and re-install TWRP to fix this issue.
Is there an older, stable AOKP for the xt907?  I think I remember seeing it for 4.2.2 back in the day but I can't seem to find it.  Does anyone else have suggestions for other solid, stable ROMs with an emphasis on customization?
Thanks!
Edit:  After surfing around some more, there's a helpful response in this thread:
There's also a link to AOKP 4.2.2 August 9 release.
#11 tucstwo
Posted 21 November 2013 - 03:22 PM
Try the 10/10 build
Thanks!
Ok guys, I apologize for the issues with the most recent builds (Wifi, LTE, etc). AOKP broke something and it took us a while to dig it up. I flashed this same build on my XT926 and it was all working fine. You shouldn't have any problems now. If there is, just let me know here and I will look into it right away. Thanks guys for your patience.
#12 Rob626
Rob626
  • 87 posts
  • LocationRoswell, GA
  • Current Device(s):RAZR M, Nook HD+
Posted 22 November 2013 - 09:28 AM
Sweet. Flashed this km last night. A good.
#13 Rob626
Rob626
  • 87 posts
Posted 22 November 2013 - 05:31 PM
Aaaaaaacccccckkkkk
This is is the first AOKP ROM I've used, and i really,really like it.
Its the smoothest 4.3 rom I've used. But in the last 6 hours my phone has locked up and needed a reboot twice. I hate that. It's happened on every 4.3 ROM I've used and every time I've used Dynamic Notifications (which I'm not using now since Active Notifications is built in)
It's happened on CM10.1.3 but not as often.
Help meeeee.
Happily the 4.4 Roms have frozen less often, so that's promising, but I have other problems on those.
Sent from my BN NookHD+ using Tapatalk 4
#14 tucstwo
Posted 28 November 2013 - 08:19 PM
Ron updated tonight, Happy Turkey Day!!!
#15 tucstwo
Posted 28 November 2013 - 08:20 PM
Aaaaaaacccccckkkkk
Help meeeee.
And sit tight, I'm working daily on getting this Rom working on this device for Android 4.4. It's coming!
  • Noigel, jco23 and Rob626 like this
#16 Rob626
Rob626
  • 87 posts
Posted 29 November 2013 - 05:29 AM
Very cool. Any insights into why my phone or at least my screen seems to shut down and lock on most 4.4 and custom 4.3 ROMs? Only reason I wonder if it's just the screen and not the phone is that if I have a text or email waiting the led blinks but I can't wake the phone. Seems much less prevalent on CM 10.1.3 and recent CM 10.2 nightlies. Most searches usually result in "get a replacement" but I'm not ready to do that yet. Edit: lost 4g altogether last night or today. Swung by my local VZW store and got a new one. I'll see if that helps my shutdowns. Sent from my XT907 using Tapatalk
#17 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Posted 04 December 2013 - 07:20 PM
Updated 12/4/13
md5: d72cb43bbe869bf9198827db1d54e1d4
#18 tucstwo
Posted 13 December 2013 - 05:37 PM
This rom is now deprecated. We will no longer be updating AOKP 4.3 (JB-MR2). If you wish to try the ALPHA 4.4.2 build,
. This will be updated regularly and as AOKP adds features, they will appear.
Also tagged with one or more of these keywords: rom, aokp, xt907
