(ROM) GZR Presents Validus13 (4.4)(CM Based)
88 replies to this topic
#1 somber73
somber73
    Ringmaster
  • 466 posts
  • Twitter:@xSomber73
  • LocationNY
  • Current Device(s):Razr M
Posted 30 November 2013 - 12:12 PM
Validus 13 Features 2.0
Alternate default app picker;
Network stats in status bar;
Network stats custom colors;
CPU info overlay;
Screenshot quick trash;
Navigation bar customization;
Improved scrolling cache;
New power mwnu from SlimRoms;
RAM bar;
Halo;
ChangeLog
Build 2 - 29.11.13
- Ported TRDS from Beergang
- New kitkat dialer icon;
Build 1.6 - 26.11.13
- Merged android KRT16S;
- Clear recents button;
- RAM bar;
- Quick unlock control;
- Halo;
Build 1.5 - 17.11.13
- Improved scrolling cache;
& Latest
Thank U's:
CM                                         DRDevs
Slim                                        DroidRzr.com
ChameleonOS                        Cristiano Matos
AOKP
Dirty
                         And Many More.......
Aeries Productions
JaeKar99
Google
Our Dedicated Community
Edited by satman80, 27 December 2013 - 08:45 PM.
gapps link latest
  • satman80 and jtommyj like this
#2 dragon
dragon
    Puff the Magic Dragon
  • 166 posts
  • Twitter:foamerman
  • LocationLand of Honalee
  • Current Device(s):Unlocked RAZR MAXX HD retired Bionic, Thunderbolt and OG Droid
Posted 30 November 2013 - 06:45 PM
Cool going to try this out first thing in the morning getting to drunk right now yea-ha :D    Oh Thank you....
EDIT O yeah First :p
  • asilentcivilian likes this
#3 HDWILLIAMS
HDWILLIAMS
  • 41 posts
  • LocationCalifornia
  • Current Device(s):XT1254,Acer A200
Posted 01 December 2013 - 07:47 AM
Nice Rom. Had it since yesterday. Very smooth.
#4 jeff0r3
jeff0r3
  • 55 posts
  • Current Device(s):xt926
Posted 01 December 2013 - 08:57 AM
I'm on a 4.3 ROM.  Is there anything special I need to do to flash this rom?
#5 dragon
dragon
  • 166 posts
  • Twitter:foamerman
Posted 01 December 2013 - 10:27 AM
No just make a Backup. Just remember to make a backup. Wipe and have fun. I know I am.
Moving on somber73 is there a way to change the color of the buttons home and back buttons? I kinda think there is but this is my first 4.4 rom I like it so far Thank You.  :)
EDIT somber73 no worries I found it just had to look a little farther
#6 jeff0r3
jeff0r3
  • 55 posts
Posted 01 December 2013 - 03:43 PM
OK, first off...  Thanks to the Devs for this great ROM.  A few initial issues.  I had no WiFi when I installed this.  For some reason it wouldn't let me sync my Google account without WiFi. I was able to get it going at the local McDonalds.  Next issue, there was no keyboard.  I was able to go into settings.  Deselect the keyboard.  Reselect it and it was there.  Next issue that just encountered is swype isn't working.  I remember having this problem the last time I used a pa gapps..  Again..  ROM is smooth!  Thanks again.  Everyone should try it..
One question.  When I try to do a nand backup it fails when I try to do it on SD card?  I then did a nand and save it on internal. However when I attempt to move it from the internal to the sdcard it fails?  Any suggestions?  My sdcard is 32gb.  Is that the problem
#7 HDWILLIAMS
HDWILLIAMS
  • 41 posts
Posted 01 December 2013 - 04:07 PM
Do a full wipe and repeat the process. And also do you have the latest recovery. I.E TWRP or Cwm?
#8 chdwrk
chdwrk
  • 36 posts
  • Twitter:workca
  • Locationnear Buffalo, NY
  • Current Device(s):Razr, Razr HD
Posted 01 December 2013 - 05:21 PM
With the 4.4 roms I've noticed that the external storage is read only. At least on my phone anyway.
#9 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 02 December 2013 - 06:01 AM
Will be remedied in next build
#10 cmh714
Posted 02 December 2013 - 06:38 AM
You need to edit the /etc/permissions/platform.xml file and add to the section WRITE_EXTERNAL_STORAGE the line:
<group gid="media_rw" />
and reboot. I posted this fix I think in Tucstwos AOSP thread, I got it from XDA....
  • rzrtm and jeff0r3 like this
#11 shockwaver
shockwaver
  • 8 posts
Posted 02 December 2013 - 08:27 AM
So the sms not working i keep getting invalid destination adress. any ideas?
#12 satman80
satman80
    Gny. Sgt. Hartman
  • 3,159 posts
  • LocationPluto
Posted 02 December 2013 - 12:55 PM
Love it!!! Nice work! :)
Site Rules and Guidelines
#13 newskate9
newskate9
    Older Than You
  • 514 posts
  • LocationCentral PA
Posted 02 December 2013 - 03:54 PM
This is NOT a critique - but merely a question.
OSE is my daily driver.  I installed this - it is smooth for sure.  Loaded up apps, adblocker started, etc.  Rebooted a few times and let her settle in a bit.  Quad scores averaging 4100 at best, versus OSE 4.4 around 5600.
As both of these are 4.4, any thoughts on why such the difference?  I could see a few hundred points, but almost 30%?
Proud father of a US Marine
#14 jeff0r3
jeff0r3
  • 55 posts
Posted 02 December 2013 - 04:24 PM
Thanks brotha!  Worked like a champ!  I haven't had one issue with this rom at all.  Absolutely lovin it!!
Are you experiencing any lag?  I read somewhere about another rom has low Quad scores.  Would be interested to know this as well.
Edit:  PS.  How do I get rid of HALO?
#15 newskate9
newskate9
    Older Than You
  • 514 posts
Posted 03 December 2013 - 03:15 AM
Lag - I did have some noticeable lag on one of the updates, I think it was 11/27.  After that it was just about gone.  It still isn't as "snappy" as I'd like, but it is hardly noticeable at all now with the latest updates.  Not sure what changed if anything, maybe I'm just getting too old!
Not sure how to get rid of halo, but I believe there IS a way to turn it off.
#16 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
  • Twitter:Rinkle_McBally
  • LocationForest Lake MN
Posted 03 December 2013 - 03:35 AM
Is halo on your screen? If so just drag and drop like you'd do any other icon
  • jeff0r3 likes this
#17 newskate9
newskate9
    Older Than You
  • 514 posts
Posted 03 December 2013 - 04:06 AM
I did this too:  Double tap + hold it until you can move it, then drag it to the red circle with cross at the top of your screen.
#18 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 03 December 2013 - 05:11 AM
Yeah i added into my next build should be fine in 2.1 when released
  • cmh714 likes this
#19 jeff0r3
jeff0r3
  • 55 posts
Posted 03 December 2013 - 04:08 PM
Thanks!
  • Rinkle McBally likes this
#20 rzrtm
rzrtm
  • 14 posts
Posted 03 December 2013 - 06:43 PM
Loving the way this ROM runs, I've had no issues so far or FC. Thanks dev beautiful work!
  • somber73 likes this
