(ROM) GZR Presents Validus13 (4.4)(CM Based)
88 replies to this topic
#21 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 03 December 2013 - 07:14 PM
Running nice on the ol' HD atta boy johnny
  • somber73 likes this
sig made by
Rinkle McBally
#22 newskate9
newskate9
    Older Than You
  • 514 posts
  • LocationCentral PA
Posted 08 December 2013 - 10:05 AM
Can't get past bootloop on 2.1. Dirty and then clean install both hang up.
Proud father of a US Marine
#23 houch80
houch80
  • 96 posts
  • LocationIllinois
Posted 08 December 2013 - 12:08 PM
Same here, I can't boot once I install 2.1.
#24 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
  • Twitter:Rinkle_McBally
  • LocationForest Lake MN
Posted 08 December 2013 - 12:33 PM
2.1 has been pulled. We found a issue and are rebuilding
  • jtommyj likes this
#25 jeff0r3
jeff0r3
  • 55 posts
  • Current Device(s):xt926
Posted 15 December 2013 - 10:37 AM
xt926 3.0 coming soon i hope?
Also, is anyone noticing significant WiFi speed issues with the 4.4 roms?  Really terrible speeds that I have noticed...
#26 SawBlade864
SawBlade864
  • 5 posts
Posted 17 December 2013 - 07:57 PM
I am getting an error whenever I try to turn on my wifi hotspot. Once this error occurs I am then unable to turn my wifi back on. I have to then wipe cache to get wifi to work again. Is anyone else having the same issue or does anyone know a fix?
#27 ol`DXer
ol`DXer
  • LocationMilwaukee, WI
  • Current Device(s):Droid Razr MaxxHD, Samsung Galaxy Note 3
Posted 19 December 2013 - 11:14 AM
I have the exact same problem. Too bad cause it’s my favorite rom :(
#28 somber73
somber73
    Ringmaster
  • 466 posts
  • Twitter:@xSomber73
  • LocationNY
Posted 19 December 2013 - 01:59 PM
I'llask around see if anyone else has had any issues
  • HDWILLIAMS likes this
#29 jeff0r3
jeff0r3
  • 55 posts
Posted 24 December 2013 - 01:04 PM
Wouldn't it be good to put the last date the rom was updated into the title of this Thread?  I went way too many days without updating because I just didn't know.  It would make it a lot easier to keep up with updates and I guarantee would get a lot more downloads..  I always look for the newest builds whenever i change roms and this would only help.  Why wouldn't this be the standard?  I see on Statistics that there is a 12-22 build :) :) :) .  Very happy with the current 3.0 .  Best rom I've run yet!!  Merry Christmas to all!!
#30 NAKAMONIEL
NAKAMONIEL
  • 59 posts
Posted 24 December 2013 - 01:57 PM
3.0 fixed all bluetooth issues, however wifi tether is now broken that was working just fine in 2.0, is 4.0 on its way by any chance? or may be new year will start with new ROM, oh well happy holidays, enjoying the rom
#31 asilentcivilian
asilentcivilian
  • 28 posts
Posted 27 December 2013 - 05:18 AM
just flashed 3.5 and experiencing bootlooping right after the motorola logo. did a full wipe, even tried mounting system prior to install. anyone else?
#32 newskate9
newskate9
    Older Than You
  • 514 posts
Posted 27 December 2013 - 06:16 AM
Nope, installed fine. Can't get root though to run.
#33 asilentcivilian
asilentcivilian
  • 28 posts
Posted 27 December 2013 - 06:18 AM
damn. i'll try re-downloading again.
#34 newskate9
newskate9
    Older Than You
  • 514 posts
Posted 27 December 2013 - 06:20 AM
How long did you let it run? It does take a while to boot first time.
And wipe every thing if you didn't.
#35 asilentcivilian
asilentcivilian
  • 28 posts
Posted 27 December 2013 - 06:36 AM
ended up being a bad download. it's at the splash screen now. thanks!
#36 newskate9
newskate9
    Older Than You
  • 514 posts
Posted 27 December 2013 - 07:18 AM
You're welcome - although, YOU did everything right, even to the point of redownloading!  So I don't think I helped too much!  Well done.
Let me know if you get root.  Sometimes, with these 4.4 roms, root doesn't work.  Then I change the SuperSU settings and it works, but each one may be different.  On this ROM, I've not found the right settings to change yet.
#37 asilentcivilian
asilentcivilian
  • 28 posts
Posted 27 December 2013 - 07:30 AM
i can't remember which ROM it was (it was an early 4.4) but i do recall having to flash the SuperSU app right after flashing gapps.  That allowed root privileges.  Eventually it was fixed and you didn't have to flash the app.  maybe we have to do that on this one too?
#38 newskate9
newskate9
    Older Than You
  • 514 posts
Posted 27 December 2013 - 08:15 AM
I tried your idea - installing Superuser, and then SuperSU.  Nothing worked,  Still don't have root.  I'm going to sit here awhile on this ROM till someone chimes in with some more suggestions.  Hoping to learn something new!
#39 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 27 December 2013 - 12:16 PM
Did you enable root in dev settings? root works fine on my 907
#40 newskate9
newskate9
    Older Than You
  • 514 posts
Posted 27 December 2013 - 12:35 PM
Hey there!  Well, let's say, I thought I did.  I get into superuser in dev section - in settings it gives options:  no, adb, apps, adb and apps.  I've tried them all, with no positive outcome so far.  Is that the setting I'm looking for?
