Is it me or did we lost some goodies on 3.5?? where is active display? and lock screen menus?
(ROM) GZR Presents Validus13 (4.4)(CM Based)
#41
Posted 27 December 2013 - 01:11 PM
- SawBlade864 likes this
#42
Posted 27 December 2013 - 05:50 PM
#43
Posted 27 December 2013 - 08:18 PM
Hey there! Well, let's say, I thought I did. I get into superuser in dev section - in settings it gives options: no, adb, apps, adb and apps. I've tried them all, with no positive outcome so far. Is that the setting I'm looking for?
I tried as well. No go for me
#44
Posted 27 December 2013 - 11:48 PM
Nope, installed fine. Can't get root though to run.
If you have trouble with root, mount system in TWRP, and flash this
Reboot, then you should be good, don't forget to update binary, reboot, and all should be good...
It's late but hope that helps.. Cheers!!
#45
Posted 27 December 2013 - 11:51 PM
Also to get DEV options make sure you click "Build Number" in settings, About phone, 7 times
- somber73 likes this
#46
Posted 28 December 2013 - 04:47 AM
Sweet - this DID work. Question though - why did we need this? Seems some folks had root and others didn't. I wiped / installed numerous times this ROM, with no issues / looping / etc.
Thanks again, for sending this out! Just trying to learn something new!
Proud father of a US Marine
#47
Posted 28 December 2013 - 10:58 AM
#48
Posted 29 December 2013 - 08:47 AM
They have never charged me for using it and I use it all the time..
- asilentcivilian likes this
#49
Posted 29 December 2013 - 11:47 AM
I am having problems flashing too, it says failed to mount system ( I did try both, regular install like i have been doing tlll 3.0 and I mounted system manually and tried again, yet it didnt working) however i can download and install 3.0 again just fine, did make sure md5 was correct too, did any1 faced/ resolved same issue?
#50
Posted 30 December 2013 - 03:28 PM
Same here. Can't figure it out.I am having problems flashing too, it says failed to mount system ( I did try both, regular install like i have been doing tlll 3.0 and I mounted system manually and tried again, yet it didnt working) however i can download and install 3.0 again just fine, did make sure md5 was correct too, did any1 faced/ resolved same issue?
#51
Posted 30 December 2013 - 03:30 PM
First Somber release I've seen problems with. Must be woman problems!! : : :
#52
Posted 30 December 2013 - 03:34 PM
#53
Posted 02 January 2014 - 01:17 PM
does this Rom have the google now widget? the swipe to left widget that is.
#54
Posted 02 January 2014 - 01:19 PM
Sent from my Droid Razr HD using Tapatalk
#55
Posted 03 January 2014 - 01:22 AM
#57
Posted 04 January 2014 - 11:47 PM
Having issues flashing 3.7 as well. It says:
set_metadata_recursive: some changes failed
E: Error executing updater binary in zip etc.
TWRP 2.5.0.0
- bigdanmeys13 likes this
#58
Posted 05 January 2014 - 12:48 AM
#59
Tried flashing both v3.5 and v3.7 and neither will flash. "Failed to run update script". TWRP 2.6.3.0 Any ideas?Sent from my XT926 using Tapatalk
#60
Posted 05 January 2014 - 12:56 AM
Apologies for the above two quotes... My phone decided to spaz out... Must be this ROM I'm on...
