Unlocked and rooted.
Was on latest CM 10.2 nightly.
started coming in and out and eventually I just lost 4g. Everything else was fine.Friday I went to the store and got a new
. Since I was still on CM10.2, I couldn't *228 and reactivate because the keyboard doesn't come up once you connect, but eventually, after a few reboots my 4g was back.As an aside, they noticed I was unlocked and rooted but since it was a reseller, not a corp store, I think they let it slide.
4g works fine the rest of the day Friday.
Saturday, does the same thing. In and out and then finally lost.
Powered off and replaced
a few times. No luck.Wiped and flashed my last verion of Stock and still no luck.
Went into ##7764726 and found where I could force
only (You can't do it through stock settings)Reboot and 4g works fine, but I lost regular
. ie; can't make phone calls.Went into settings, toggled between Global --- LTE/
got my mobile service back, but lost 4g again.Did this a few times. Consistently the same results.
I haven't used Matt's utility yet to go back to bone stock, but before I do that, any other ideas?
TIA
