Twitter Facebook
Issue With Silent Mode/vibrate
  • You cannot start a new topic
4 replies to this topic
#1 fosser2
fosser2
  • 40 posts
Posted 15 July 2012 - 05:30 PM
Ever since the upgrade to .211 (ICS) I have an issue where if you use the physical volume buttons and turn the phone all the way down it eventually mutes all sound. This should only be the case if silent mode is selected in settings/sound but I have it set to vibrate mode. Is there any known way to fix this issue or is this a bug in ICS? Thanks for the reply's.
I am now on the .215 leak and this issue still persists.
#2 ogrekane313
ogrekane313
  • 72 posts
Posted 15 July 2012 - 05:54 PM
its normal it does like htc. if you use button to go all the way down it goes to vibrate only then one more click is silent all
#3 runner1717
runner1717
  • 32 posts
Press and hold the power button and select either mute or vibrate at the bottom of the screen that pops up. The screen you show doesn't hold anyway. Once you reboot it reverts right back to vibrate.
Mike
#4 arcanexvi
arcanexvi
    Property of Roo
  • 838 posts
  • LocationSchaumburg, IL
Posted 15 July 2012 - 06:15 PM
It's working as intended not a bug. I got used to it quickly.
#5 fosser2
fosser2
  • 40 posts
Posted 15 July 2012 - 06:18 PM
Alright, Thanks for the reply's guys. I guess I'll learn to live with it :)
