I have been using RAGEHD 2.1 on Razr Maxx HD (XT926). After completely wiping and installing RAGE HD ver 2.5, I have some icons left at top from earlier flashes.
44.97KB 7 downloads How can I get rid of them?Old icons after flashing
Posted 30 January 2014 - 07:51 AM
Posted 30 January 2014 - 07:52 AM
The ones on left side.
Posted 30 January 2014 - 07:57 AM
The light blue ones on the far left?
Those are icons from apps you have installed
Posted 30 January 2014 - 07:59 AM
One is a battery mod app, but I haven't reinstalled after wiping and reflashing. Shouldn't that have gotten rid of it?
Posted 30 January 2014 - 08:00 AM
Did you use titanium backup or an app like that to restore anything??
Posted 30 January 2014 - 08:02 AM
I restored my Apex settings and desktops.
Posted 30 January 2014 - 08:07 AM
I would not think that would do it. Are there other apps installed in the app drawer that are yours and not from the rage rom? I'm thinking the data wipe did not work when you flashed the rom
Posted 30 January 2014 - 08:11 AM
One is a battery level mod I flashed back on first version of RAGE. I don't see it listed in app drawer. Looking in Tit. BU but don't really know what is name.
Posted 30 January 2014 - 08:15 AM
Ahhh so you do use tibu. Did you restore system data after you flashed??
Posted 30 January 2014 - 08:19 AM
I didn't think so, but I must have. I was having all kind of trouble getting my phone to boot, I tried multiple times, reflashing and wiping. Guess I'll have to do it again to get rid of that battery mod. Right?
Posted 30 January 2014 - 08:23 AM
Yup. Just make sure when you restore with tibu just restore apps and app data NOT system data. Of course if thos icons are from apps when you restore app data they will probably come back. You need to figure out what apps they are from and either uninstall or turn off ongoing notifications
Edit.. You should find the apps first. No sense reinstalling the rom just to get back in the same spot
- lovedgor likes this
Posted 30 January 2014 - 09:00 AM
Thanks, I don't see an app for the battery mod I installed, so I think it has to be part of the system data. I found the other one.
Thanks again.
Posted 30 January 2014 - 09:25 AM
Well, I mounted, wiped, flashed, and on the first boot, before restoring anything, that darn battery mod came back. Where the heck is it coming from?
Posted 30 January 2014 - 09:57 AM
It must be something in the rom. Might be worth posting in the rom thread. Is there any notification when you pull down the shade that relates to that app?
Posted 30 January 2014 - 10:07 AM
No, nothing in the notifications. It is from the battery mod I flashed long ago. Shows the percent of battery left.
I will post in the RAGE forum
Thanks again!!
Posted 30 January 2014 - 10:25 AM
