TWRP THEME PROBLEM
4 replies to this topic
#1 JWACK72
JWACK72
  • 103 posts
  • LocationSC
  • Current Device(s):RAZR M
Posted 08 February 2014 - 10:49 AM
Well my wife decided to give flashing a go today & not the good kind. Well as expected it did not go so HOT. She found a theme she liked, & flashed it. Turned out to be  a theme for TWRP. Now the recovery screen is off the scale & I cant do anything. I tried to find the link to reinstall it, but the link wont work. Any help would help. thanks
#2 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 08 February 2014 - 11:36 AM
I think I've used
app to install TWRP before.
#3 JWACK72
JWACK72
  • 103 posts
  • LocationSC
Posted 08 February 2014 - 01:11 PM
I need the TWRP 2.6.3 file itself, the ones I found have a problem
#4 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 08 February 2014 - 10:28 PM
Go into the TWRP folder on your internal SD, the installer should have put a "theme" folder there, with a ui.zip inside it. Just delete the "theme" folder. This should get rid of the bad theme.
#5 JWACK72
JWACK72
  • 103 posts
  • LocationSC
Posted 09 February 2014 - 03:28 AM
I got it. The developer put an SOS un zip file on the download link to remove the ui.zip .  Thank you both for the help!!
