I know it isn't advised to flash to the stock slot, but how do I do it?
I tried wiping system and stuff just like a normal slot and had to fastboot. Then I tried just flashing over stock, and nothing.
Trying to get blurry in the stock slot for something stable and leave more SD space for playing around
Sent from my Nexus 7 using Tapatalk
Safestrap stock slot question
jbag1489
, Feb 18 2014 09:22 PM
1 reply to this topic
Posted 18 February 2014 - 09:22 PM
Posted 19 February 2014 - 02:21 PM
The only way I've been able to figure out is to install your desired rom on whatever slot...back it up and then restore it on the stock side. I've done it a few times. I don't need extra play room on my sd card, 64gb is more then enough for me
