don't know device details. (saving you time) I deleted partitions on accident phone worked fine until reboot which took me to ap fastboot. laptop detects usb cable but rsd lite will NOT detect my device. (would have fixed the issue already if it did)
was rooted and unlocked with status code 3 now showing 0
If it helps, I did flash CWM with matts utility yesterday and made a backup on external SD.(so if I can access that file im happy af.
device is LOCKED.
Battery low
USB connected
Transfer mode:
failed to hab check for gpt_main: 0x35
failed to hab check for gpt_backup: 0x35
failed to load GPT
CID read failure
Invalid CID status 0x69
No SP partition found
