I am stuck on the leak, because the leak stuck on me.
[Link Updated]Safestrap 2.11 Released- See Op For Instructions 8/23/12
#21
Posted 20 August 2012 - 09:04 AM
#22
Posted 20 August 2012 - 09:52 AM
Good luck! SpyderMan
#23
Posted 20 August 2012 - 10:22 AM
#24
Posted 21 August 2012 - 07:07 AM
- lightsword likes this
#25
Posted 21 August 2012 - 10:04 PM
#26
Posted 22 August 2012 - 12:01 AM
Yeah link is dead
Try it. Lemme know.
X
#27
Posted 22 August 2012 - 03:49 AM
Try it. Lemme know.
X
That worked. Thanks.
#28
Posted 22 August 2012 - 03:53 AM
#29
Posted 22 August 2012 - 03:53 PM
#30
Posted 23 August 2012 - 09:14 AM
#32
Posted 23 August 2012 - 10:19 AM
destiny, did you enable recovery & do the requisite wipes b4 installing?
Yes, recovery was enabled. And wipes were completed.
also, when you upgraded SS, did you remove the prev recovery & install the new one?,
Yes , unistalled SS recovery. then updated app. then installed new recovery. On one Razr it was a fresh root and install. same problem
I'm rooting 4 Razrs total. Not at the same time though.
Trying to install Simplex ROM
#33
Posted 23 August 2012 - 02:13 PM
did you have this behavior w/other roms on the same phone?
what about the other phones? does Simmplex take on them?
Maybe you need to confirm the flashing s/w & be sure you have the latest moto drivers…
which method did you use to go to 211 & root?
Will be out most of tonite, but will try to check in
#34
Posted 23 August 2012 - 03:19 PM
Sent from my Droid Razr using Tapatalk 2
#35
Posted 23 August 2012 - 04:52 PM
Anyone have a link for ss 2.11 looks like the op link host location was removed
OP updated with official links
#36
Posted 23 August 2012 - 08:20 PM
perhaps you should try to re-download the Simplex ror & confirm the MD5 checksum - usually in the OP
I have dll'd it again and checked MD5.
yes, eclipse & Simplex
no, neither rom on any of the phones. Just boot loops.
yep have drivers
took ota. used the EternityProject EasyRootICS to root.
I got Simplex installed with Bootmanager. but media & moto input fc'd. It was really weird, nothing worked well if at all.
#37
Posted 23 August 2012 - 08:42 PM
thank you sirOP updated with official links
#38
Posted 24 August 2012 - 04:15 AM
Only safestrap is the official install method for Simplex, so if people have problems using another recovery, no one can really help out.
#39
Posted 24 August 2012 - 06:10 AM
I'm not a n00b but I cannot get any roms to load through SS. I keep getting these angles boot loops or just black screen. I follows the instructions to a T.Only safestrap is the official install method for Simplex, so if people have problems using another recovery, no one can really help out.
#40
Posted 24 August 2012 - 06:14 AM
If your're getting bootloops and black screens than there is a bigger problem. Which version of SS are you use? Do you always wipe everything before you flash? Maybe you need to FXZ your phone. There could be something corrupted. I understand your not a noob, but your experience with safestrap isn't a typical one, so obviously you have some kind of unique problem. And when a dev said, this rom only works with SS and you install with boot manager and have problems who is to blame? Simplex works just fine on my phone. And so does Safestrap. There must be SOMETHING that you're missing. What are your install steps from the moment you turn your phone on stock-rooted with no recovery installed to when you boot up a rom?
