[Rom][Bionic] Tormented Kang
Posted 20 August 2012 - 02:12 PM
THIS HERE IS THE START OF A SERIES OF KANGS I AM GOING TO DO
JUST FOR FUN AND PRACTICE.
THEY WILL ALWAYS HAVE ONE THING IN COMMON SPEED. IT GOING TO BE FAST.
TEAM HATERS PRESENTS
A OVERCLOCKED KANGED CM10 ALPHA BUILD FOR THE BIONC
MODS
5 DIFF GOVS
OVERCLOCKED TO 1.27GHZ
BUILD PROP TWEAKS
CUSTOM WALPAPERS
V6 SUPERCHARGER TWEAKS
Thank u Markus for 1% mod
INSTRUCTIONS
DOWNLOAD ROM AND GRAB JELLY BEAN GAPPS
SAFESTRAP 2.10 ONLY
WIPE DATA FACTORY RESET
WIPE SYSTEM
FLASH ROM
THEN FLASH GAPPS
REBOOT AND ENJOY
I WOULD REBOOT TWICE AFTER SETUP.
DOWNLOAD ... ToRmEnTeD KaNg --- Rom by sparkyman216 copied over from rombot.org
MODS
5 DIFF GOVS
BUILD PROP TWEAKS
CUSTOM WALPAPERS
INSTRUCTIONS
SAFESTRAP 2.10 ONLY
WIPE SYSTEM
FLASH ROM
THEN FLASH GAPPS
REBOOT AND ENJOY
DOWNLOAD ... http://crackflasher.com/dev/mattlgroff/XT875.Verizon.en.US/ToRmEnTeD_KaNg_v4.zip
- T3T3droid likes this
Posted 20 August 2012 - 03:15 PM
Animated battery charge previews are APNGs. They are only viewable with Firefox, Opera, or Chrome (Chrome must have APNG extension installed)
Previews:
Binary - "For the geek in all of us" *Icons created by me* [Read the same way as a binary clock]
^Thats 97% as an example^
Outline - *Icons created by me*
Off Center - *Icons created by mrvirgina*
Thin Circle - *Icons created by nbeebe24*
White Number - *Icons originally included in sparkymans Gnex ROM*
Note: Battery charging animations start wherever your battery is charged to when plugged in. They will not start off at 0% every time.
Install: Flash zips in Safe Strap.
Links:
Binary -
Outline -
Off Center -
Thin Circle -
White Number -
Ill upload some more at some point with icons already made by other people and credit them correctly. As the ROM updates Ill modify the SystemUI.apk so the default icons dont get overwritten except the battery icons.
- mattlgroff likes this
Posted 25 August 2012 - 09:54 AM
Posted 30 August 2012 - 08:27 AM
Posted 30 August 2012 - 04:27 PM
Posted 30 August 2012 - 09:19 PM
When has the OP been updated? Any reason you have to use 2.1 or can you use 2.11? I know..... probably a dumb question but I just wanted to be sure
You can use either
Posted 31 August 2012 - 05:15 AM
Posted 31 August 2012 - 05:16 AM
Posted 31 August 2012 - 06:06 AM
Great job Sparky! Getting fantastic battery life! Data very strong once connected.
what was your trick to get data connected? lol
Posted 31 August 2012 - 08:18 AM
Normal process...wipe data factory reset ,format system, install zips, wipe dalvik, reboot, setup all apps ( wifi for now) , reboot twice, bingo! did not have to mess with phone info testing screen or settings in mobile...wait for a few minutes switches between modes then connects to lte/gsm/cdma...leave it there...wifi off and on still came back....if i had to reboot it wouldnt reconnect.. so as long as i kept charging the battery when it got low i was ok...
edit: I have had it hook up if i wait a few minutes before going into setup...
Posted 31 August 2012 - 12:17 PM
1) Let phone boot up and WAIT till you have signal bars
2) Go into Settings>More...>Mobile Networks OR use Phone Info
3) Switch the Network Mode from GSM to LTE/CDMA/EvDo/GSM/WCDMA
4) Reboot and repeat the process until you get data connected.
*If you have troubles handing off to LTE, cant get a LTE connection with this ROM, or live in a 4G area and cant get data with the above method try switching the Network Mode to CDMA/EvDo Auto within Settings app OR if using Phone Info switch to CDMA Auto (PRL) in step 3*
This way it will ignore the LTE signal and continue to stay connected to 3G. Some people got LTE just fine, I was not one of those people...
Posted 01 September 2012 - 08:25 AM
Otherwise data will never work.
Posted 19 October 2012 - 12:42 PM
Posted 02 November 2012 - 10:03 AM
Posted 02 November 2012 - 10:22 AM
There are lots of jelly bean roms out with 4g working, just check in the droid bionic roms sectionSucks 4G wont work! I have tried about every method! This is a smooth Rom and works good, But dangit
