Question about XT926 part
2 replies to this topic
#1 Guest_RCOO_*
Guest_RCOO_*
Posted 15 March 2014 - 04:39 PM
So, I've bought my RAZR MAXX HD a few weeks ago and have been overall happy.
I've tried a new cape today, and I noticed the front part of my screen was popping out...
I took it off and ended up with
in my hand, and the "actual" screen of the device showing.
The actual screen was pretty scuffed up so I decided I would continue to use the part that came off.
My question is: this part has some glue that allows it to stick to the actual phone . If I buy a new part online, like
, where do I get the proper glue, so it doesn't damage the actual screen?
Thanks!
#2 cmh714
Posted 16 March 2014 - 06:39 AM
I had to remove the back and replace my headphone jack but didnt have any issues with glue inside....
you can try something here:
#3 Guest_RCOO_*
Guest_RCOO_*
Posted 16 March 2014 - 06:41 AM
Yea... That's probably it. I have to get the tape and apply it to the screen i buy...
Thanks!
