Wiping Cache
9 replies to this topic
#1 SeaBee
SeaBee
  • 18 posts
Posted 22 March 2014 - 03:28 AM
OK...so I am trying to wipe my cache (Build: 9.8.1Q-94-1)
- from phone off, hold vol up & down + power
- menu comes up, vol down to RECOVERY
- wait for "!" and hold vol down, then press vol up
- menu comes up, vol down to WIPE CACHE and press power key
OK, from there it says it is wiping....but nothing happens. It just stays on that screen. Any ideas?
#2 johnthehillbilly
Posted 22 March 2014 - 03:39 AM
Could be you're cache is rather large..... And taking a while to wipe?.....
Also, are you rooted? .... If so, you can install safestrap then wiping cache and dalvik cache is easy peasy :)
#3 johnthehillbilly
BTW ..... I love the username and avatar!!!!! Go navy!!!!! (Former FC3 SW)
#4 SeaBee
SeaBee
  • 18 posts
Posted 22 March 2014 - 03:53 AM
Nice shipwreck (I mean shipmate), I am with NMCB14 - EO2(SCW)
#5 SeaBee
SeaBee
  • 18 posts
Posted 22 March 2014 - 03:55 AM
OK I got it off of google play and no matter what I try, it says "Unfortunately, Boot Menu S Manager has stopped"
Any ideas?
#6 johnthehillbilly
Posted 22 March 2014 - 04:03 AM
At the top of our page (droidrzr.com).....Go to forums .... android general... Hashcodes corner .... You should be able to find safestrap for your device....... (I font have it right off hand or I would upload it for you) ...... Get rid of that one from play store, it may not play nice :)
#7 johnthehillbilly
Posted 22 March 2014 - 04:04 AM
And you need to be rooted for it to work :)
#8 SeaBee
SeaBee
  • 18 posts
Posted 22 March 2014 - 04:14 AM
Hmmmm....I could of swore I read that the XT907 with my build could not be rooted. I have to get to work, but will look into it more later. If you have anything that will help...it is appreciated!
#9 johnthehillbilly
Posted 22 March 2014 - 04:19 AM
It can be now :););) ....
#10 johnthehillbilly
Posted 22 March 2014 - 04:20 AM
Once you're rooted tho, if you don't want to install safestrap....... You can use a root explorer (or ADB) and manually wipe cache and dalvik cache :)
