What 4.4 roms work for Safestrap?
12 replies to this topic
#1 nal
nal
  • 164 posts
  • LocationIllinois
  • Current Device(s):Droid Razr HD xt907/26, LG G2, Nexus 7 2012
Posted 22 March 2014 - 07:18 PM
title.
I'm running safestrap with 98.30.1 and I want to switch to 4.4 any roms? I was looking at cm11 but I don't know if it has ss support
#2 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 22 March 2014 - 10:28 PM
CM11 is not compatible with SS.  As far as I know there is no 4.4 out right that is compatible with SS.  Once the 4.4 OTA is released, we should have many stock AND aftermarket 4.4 ROMs that are compatible with SS.
  • shane1 likes this
#3 nal
nal
  • 164 posts
  • LocationIllinois
Posted 23 March 2014 - 06:52 AM
So should I not upgrade to 4.4 when its released?
Will it be possible to unlock the bootloader when it comes out?
Will there be anything for rooting? Sorry, I'm a new user to android and I'm just wondering if I should stay with 4.1.2
#4 livinginkaos
Posted 23 March 2014 - 07:14 AM
If you are not currently unlocked you will not be able to. That exploit has been patched and it was reported that there are no other holes to use. I would not plan on root for 4.4 at this point. Just watch for a bit after the update happens before taking it to weigh your choices
Sent From My DEV X
  • RikRong likes this
#5 soundgirl101
soundgirl101
    CM11 KitKat Addict
  • 94 posts
  • Current Device(s):DROID OG RAZR MAXX
Posted 23 March 2014 - 02:26 PM
:huh:  I don't see a reference to any device?? Razr Maxx xt912 runs CM11 KitKat 4.4.2 with Safestrap 3.65 on slot1, JBX custom kernel can be flashed as well for extra options, proud to note as well, HDMI IS working in CM11 on xt912!!  :wub
xt912 CM11 KitKat, JBX Powered, SS3.72 Slot 1
#6 livinginkaos
Posted 23 March 2014 - 03:04 PM
That system version is the HD/M series. Since the bootloader was unlocked for those devices, there was very little effort put into safe strap versions of anything beyond that time..
Sent From My DEV X
#7 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 23 March 2014 - 03:10 PM
title.
:huh:  I don't see a reference to any device?? Razr Maxx xt912 runs CM11 KitKat 4.4.2 with Safestrap 3.65 on slot1, JBX custom kernel can be flashed as well for extra options, proud to note as well, HDMI IS working in CM11 on xt912!!  :wub:
98.30.1 belongs to the HD/M. ;)
#8 nal
nal
  • 164 posts
  • LocationIllinois
Posted 23 March 2014 - 04:02 PM
98.30.1 razr m???
so uh
can I?  I hear yes's and no's
#9 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 23 March 2014 - 04:48 PM
98.30.1 razr m???
so uh
As previously stated, there is no CM11 for the M that is compatible with SS.  As for updating when 4.4 comes out...I would wait for the devs to get hold of it and make a pre-rooted custom ROM.
#10 nal
nal
  • 164 posts
  • LocationIllinois
Posted 23 March 2014 - 05:46 PM
what roms can I go with for the time being?
#11 rwrutl
rwrutl
    Droid Devotee'
  • 37 posts
  • LocationCleveland TN
Posted 08 June 2014 - 09:01 AM
I have a safestrap specific question. Is there a certain version to use on the Bionic to install CM11 ?  Any advice appreciated
#12 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
  • LocationWhere I AM
Posted 08 June 2014 - 01:34 PM
Any SS version 3.60 or higher is recommended for installing KK Roms on the Bionic. Hashcode has his tread updated with the 3.7x version that work as well. Happy modding...
Sent from my VS980 4G
  • Thach and RikRong like this
#13 rwrutl
rwrutl
    Droid Devotee'
  • 37 posts
Posted 09 June 2014 - 04:48 AM
Thanks, and in the meantime I had found the Targa specific SS 3.73 and finally did get CM11 installed on my Bionic. No going back, lol  Thanks again
