[Rom][Razr-Cdma-Non-Kexec-Overclocked] *updated* Jekyll Cm9 V1.4.1 9/23/12 {Now Optional Softkeys!}
cm9 jekyll ics
266 replies to this topic
#21 andermk
andermk
Posted 16 September 2012 - 05:29 AM
This rom is fantastic. Thanks for your work.
#22 desireaftergod
desireaftergod
  • 536 posts
  • LocationNH
Posted 16 September 2012 - 09:22 AM
Just curious, with this being overclocked, how hot does the phone get?
#23 tucstwo
  • Google+:tucstwo@gmail.com
Posted 16 September 2012 - 09:54 AM
I've only run it for less than 24 hours myself. After I get a couple days worth, Ill post temp logs. So far, I haven't gone over 31C
#24 tucstwo
Posted 16 September 2012 - 09:55 AM
Google play store keeps force closing. Could u fix it soon? Thanks
I'm sorry, Ill take a look at that. I haven't had it happen to my phone. If anyone else has, can you report?
#25 CaniTouchYaSoul
CaniTouchYaSoul
  • 34 posts
Posted 16 September 2012 - 11:45 AM
Great Rom... I need a better battery indicator? or is there something i can do to see the percentage?
#26 logan3824
logan3824
  • 308 posts
  • LocationHouston, Texas. GO TEXANS!
Posted 16 September 2012 - 12:20 PM
Go into settings > system > Status bar > battery and click percentage.
#27 jrbxx7
jrbxx7
  • 94 posts
  • LocationIdaho
Posted 16 September 2012 - 01:10 PM
Can you tell me about how long it should take on the first boot... never got past the boot screen. just wondering if i waited long enough...
GOT KRACKFLASHING?
#28 brajonrondo
brajonrondo
Posted 16 September 2012 - 01:29 PM
Is anyone else able to hear when the phone is NOT on speaker? This is not the standard 4.0 Bluetooth bug but rather the fact that I get no phone audio unless the phone is on speaker.
Other than that this rom is awesome!
#29 Marukka562
Marukka562
  • 10 posts
Posted 16 September 2012 - 01:40 PM
Easy fix, turn off bluetooth if you're not using it :)
#30 tucstwo
Posted 16 September 2012 - 02:46 PM
the bluetooth bug is a kernel level problem. It will most likely NEVER be fixed outside of Kexec. And yes, this Rom takes a LONG time to perform an initial boot. I'm gonna be consolidating stuff to avoid that in a future build. Remember: this is 1.0 ;)
  • mugsy77 likes this
#31 srzero
srzero
  • 370 posts
  • LocationArlington
Posted 16 September 2012 - 02:48 PM
Just flashed the ROM. GREAT work. Think I'm gonna run this for awhile. I was iffy about the small keyboard, but its pretty accurate. If I were to make my own script and up the CPU, would it cause conflict with the current settings? Or just over ride them?
My quad score :D
  51.48KB   43 downloads
Sent from my CarbonRAZR using Tapatalk 2
Make It Your Own
#32 jrbxx7
jrbxx7
  • 94 posts
  • LocationIdaho
Posted 16 September 2012 - 02:59 PM
ok i waited like 25 mins and didnt get past boot. ill give it another try. Thanks!
GOT KRACKFLASHING?
#33 srzero
srzero
  • 370 posts
  • LocationArlington
Posted 16 September 2012 - 03:02 PM
@1380
  52.62KB   46 downloads
Make It Your Own
#34 Maxxaholic
Maxxaholic
  • 628 posts
  • LocationWashington, USA
Posted 16 September 2012 - 06:43 PM
Will wait for an update to try again. Phone froze and rebooted 4 times during different tasks. I'd be on go SMS, internet or play store when it happened. I'm on .215 leak if that matters
#35 thrasher194
thrasher194
    http://androidn00b.com/
  • 226 posts
  • Google+:Thrasher194@gmail.com
  • LocationNorthCarolina, USA
  • Current Device(s):Motorola G4 Play (xt1609)
Posted 16 September 2012 - 08:54 PM
it took me like two mins before the logo popped up.. then ever other time it takes like 40sec before logo starts up.
#36 srzero
srzero
  • 370 posts
  • LocationArlington
Posted 17 September 2012 - 04:43 AM
No bad
  42.37KB   63 downloads
  41.34KB   57 downloads
Make It Your Own
#37 srzero
srzero
  • 370 posts
  • LocationArlington
Posted 17 September 2012 - 05:20 AM
My flash doesn't seem to work. When I tap to focus it lights up, but when taking a picture it doesn't.
Make It Your Own
#38 pcavuoto
pcavuoto
  • 63 posts
  • Twitter:pcavuoto
Posted 17 September 2012 - 06:03 AM
Does smart actions work with this rom?
#39 srzero
srzero
  • 370 posts
  • LocationArlington
Posted 17 September 2012 - 06:52 AM
no...which kinda sucks because I use it a lot...
Make It Your Own
#40 02serv
02serv
Posted 17 September 2012 - 07:07 AM
flashed rom restored apps with titanium backup then ran quadrant @1325
Also tagged with one or more of these keywords: cm9, jekyll, ics
