Safestrap Partitions Disappearing After Reboot
6 replies to this topic
#1 Nightcatfisher
Nightcatfisher
  • 5 posts
  • LocationKansas
Posted 14 May 2014 - 04:06 PM
Today I needed to reboot my Razr HD, it booted into the stock ROM. When I came home I reinstalled Blurry ROM I was using, downloaded all the apps I was using and everything was fine. I just rebooted once again and now the partition with the Blurry ROM is gone. Any ideas why this is happening? I checked my SD card and everything including the ZIP files and all my music is still there so I am assuming the SD card is still good. Any help would be appreciated. Thanks
#2 johnthehillbilly
Posted 14 May 2014 - 04:10 PM
There are some users of the RAZR 912 having the same issue.......
Do you use the clean master app for cleaning cache and "junk" files?
#3 Nightcatfisher
Nightcatfisher
  • 5 posts
  • LocationKansas
Posted 14 May 2014 - 04:12 PM
I do but I am usually very careful with what I select to delete.
#4 johnthehillbilly
Posted 14 May 2014 - 04:17 PM
It had an update recently.... And it seems to have a mind of its own......
#5 johnthehillbilly
Posted 14 May 2014 - 04:18 PM
You may need to reinstall the old one and don't let it update.... Or go into it's settings etc and deselect the SafeStrap file from the "junk" files......
  • jl90 likes this
#6 Radio2006
Radio2006
  • 7 posts
  • Current Device(s):Droid RAZR Maxx
Posted 28 May 2014 - 03:29 PM
Ok...I am having the same issue and I just started using the stupid clean master app a day before I rebooted. Thing is, the ROM slot is clean, but the space is still allocated for it. How can I boot back into it or wipe it to resolve the issue?
#7 Radio2006
Radio2006
  • 7 posts
Posted 28 May 2014 - 04:12 PM
Disregard...booted into stock, uninstalled safestrap, wiped all sd cards, after back up of course, re-installed safestrap and all space is free again.
