Best Answer livinginkaos , 16 May 2014 - 04:41 AM
First of all, let's dispel the idea that someone seems to find root for new software. That is untrue and the more exploits that are found the more realistic that day will be that it will not be possible at all. That said, with the unlocked bootloader, you have no need for exploits because you have the ability to flash most anything, with a few exceptions to security enabled partitions such as the tz position. But, the important one is the ability to flash custom recovery. From there, the ability to root is achieved. So, in answer to your question, just go back to stock, take the update, then install the cwm for kk. Then from there, install the supersu.zip. Sent from my S-Offed One M8 Go to the full post
