Voice input missing? SOLVED
1 reply to this topic
#1 roaoro
roaoro
  • 17 posts
  • Current Device(s):Razr M
Posted 05 June 2014 - 09:18 AM
I've searched but found nothing, so I'm guessing it's not an obvious issue, but I've recently upgraded the newest OTA via the instructions here from SamuriHL (thank you), and no longer seem to have any voice input options anywhere.  I have the option checked in the keyboard settings, but it does not show up on the keyboard.  What am I missing?
#2 roaoro
roaoro
  • 17 posts
Posted 05 June 2014 - 01:54 PM
I figured it out...  I don't know why this happened to only me, but for some reason Google Search did not make it through my update process.  Installing Google Search through the play store now gives me the google voice typing option.  Hope this helps if anyone else comes across this problem.
