So now that were rooted, I figured that would mean we would be able to use the Wireless Tether flawlessly. I'm having trouble though, it either gets stuck on the loading screen or it says it's running but nothing shows up in available networks. I've used both the Wireless Tether and Wifi Tether apps. Does anybody know the proper configuration for either one or an app that works solidly?
Wireless Tether and Root
Posted 19 June 2014 - 05:51 AM
Posted 19 June 2014 - 06:05 AM
I didn't test it, but here is an exploit on XDA that seems to have positive feedback.
Posted 19 June 2014 - 06:18 AM
Sent from my S-Offed One M8
Sig by
Posted 19 June 2014 - 06:27 AM
I think he has one specifically for the xt926 as well
Posted 19 June 2014 - 06:53 AM
The other option is just using the xposed module
I actually had the xposed framework on my last phone and I never understood how it worked. How do you go about using that?
Posted 19 June 2014 - 06:58 AM
- Memnoch73 likes this
Posted 19 June 2014 - 06:59 AM
-Install exposed app
-Open app install framework
-reboot
-search for modules (wifi tether) from within exposed app
-download module
-install module
-reboot
-Profit?!
Posted 19 June 2014 - 07:12 AM
I could never get the Xposed one to work, so I stuck with Topsnake's exploit. Works like a charm, although I haven't seen nor tried the newer one he has that supposedly doesn't require replacing the apk like the original one did.
Posted 19 June 2014 - 07:29 AM
-reboot
-download module
-install module
-reboot
-Profit?!
Wow I feel silly I had that for so long...and it has so many options! Thanks!
