stuck at eletronic eye
#eye #stuckateye #stuckatelec
4 replies to this topic
#1 jlaino
jlaino
  • Current Device(s):droid razr
Posted 24 June 2014 - 06:50 AM
yes, I saw that one thread about 3 pages in. Btw, maybe its me, however; the search feature doesn't seem to work too well.
Tomorrow I plan on trying to purchase a micro USB cable though in the meanwhile I have cleared the cache and tried the recover features without any luck of getting passed the electronic eye.
The phone is completely stock and no it will not be under Verizon's warranty.
After reading a lot of posts and walls of text it still feels as if something's are taken for granted that the end user, me, knows what the hell "we" are doing. Not the case
I have downloaded the jellybean utility and have the latest Motorola 64 bit driver installed.
  • I am wondering does my phone need to be unlocked before I try to reinstall the drivers?
  • If reinstalling the drivers doesn't fix the problem what do I do next?
  • Do I need to root the phone if I decide to install jellybean?
  • Is there a way to pull the photos off the internal memory before doing all this work? This is pretty important to me. I could never quite figure out the $#!+ty filing system on this droid. Most all the photos are on memory card but not all.
  • If there is a link to these questions this would be much appreciated or just some answers.
I have a XT912 Verizon, CDMA normally though it has GSM capability. It's a global phone
Thanks!
#2 xKroniK13x
xKroniK13x
  • 284 posts
  • LocationAtlanta, GA
  • Current Device(s):Moto X 2014 Pure Edition || Motorola DROID RAZR M || Archos G9 101 || Microsoft Surface Pro 2 || Chromecast
Posted 24 June 2014 - 07:23 AM
Thanks!
If your phone is stuck on boot, it probably means that the system files are incorrect. You mentioned using the Jellybean Utility? If it is downgrading you, and your bootloader is locked, you likely softbricked your phone and need to get the correct FXZ version and redo it on House of Moto... but here are the answers to your questions!
No, the phone does not have to be unlocked for anything except for downgrading the system, or installing a custom ROM. Drivers are needed for your computer to understand how to communicate with your phone.
Installing the drivers themselves will likely not fix anything, as it is not going to alter your device. Follow the instruction for
, which will return your phone to the stock firmware.
If you are on the KitKat update, you will need to root and unlock your bootloader before going back to Jellybean.
Use the KEEPDATA script on House of Moto and your data will remain untouched... it will always remain untouched on your SD card unless you explicitly format it.
If this didn't make sense, just say so and someone/myself will attempt to find relevant threads or just write it out for you.
Moto X 2014 Pure Edition Unlocked on Pure Rooted 5.1
#3 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 24 June 2014 - 07:34 AM
Careful. He is on the OG Razr 912. There is no KK or Bootloader unlock
  • rickw and xKroniK13x like this
#4 xKroniK13x
xKroniK13x
  • 284 posts
Posted 24 June 2014 - 07:37 AM
Good catch. I even looked at the category he posted in and made a mental note, and then didn't type it out correctly. All other information should be correct... I think.
I need more coffee today.
  • Memnoch73 likes this
#5 Guest_kinnelonfire75_*
Posted 24 June 2014 - 08:34 AM
Just to get a bit of clarification since I see this is your first post.
How did you get to where you are now? Did you try doing anything to the phone like obtaining root access? Or did you just turn the phone off, and try turning it back on, which is how you got to the electronic eye?
Also, which thread "about three pages in"?
Edit: This may not be relevant yet, but which version of Android are you currently on?
