Twrp 2.7.0.0
Posted 01 July 2014 - 08:51 AM
Posted 01 July 2014 - 09:02 AM
Posted 01 July 2014 - 09:13 AM
Posted 01 July 2014 - 09:17 AM
flashify will flash an img....I can poke around some more for the zip
- Slickademo likes this
Posted 01 July 2014 - 09:22 AM
Posted 01 July 2014 - 09:50 AM
No dude. thats compatible with KK for JB you would need 2.6.3 at least thats the version I had on for JB....I may have missed a 2.7.0 version...
Posted 01 July 2014 - 10:06 AM
I'm not sure what version this is, but it's definitely not the KK version:
Posted 01 July 2014 - 11:22 AM
It installed but was unresponsive and didn't work.No dude. thats compatible with KK for JB you would need 2.6.3 at least thats the version I had on for JB....I may have missed a 2.7.0 version...
- nobe1976 likes this
Posted 01 July 2014 - 01:04 PM
I will link it to ya if you are still on the 4.1.2 bootloader. If you upgrade to kitkat official you will need to use dhackers version
Sent from my VS980 4G
Posted 01 July 2014 - 01:20 PM
Posted 01 July 2014 - 01:26 PM
,I am still on the 4.1.2 bootloader
ok since ou havent updated I think I still have the .img on the server. Will link it in a bit...
Posted 01 July 2014 - 01:31 PM
Thank you! I appreciate that. I will save the file. Don't know what happened the to IMG I had :,
Posted 01 July 2014 - 01:47 PM
This was built from that last 4.4.2 Omni Unified version I built on my Laptop before my previous Mother Board took a crap.. It should be the last updated TWRP version for your current 4.1.2 Bootloader. I am currently on the new 4.4.2 bootloader so I have no way to test and verify. This is a recovery install flash setup. Just install it from the current recovery you are on and Walla Updated next time you boot into recovery.
Posted 01 July 2014 - 04:01 PM
Thanks buddy! That worked perfectly.This was built from that last 4.4.2 Omni Unified version I built on my Laptop before my previous Mother Board took a crap.. It should be the last updated TWRP version for your current 4.1.2 Bootloader. I am currently on the new 4.4.2 bootloader so I have no way to test and verify. This is a recovery install flash setup. Just install it from the current recovery you are on and Walla Updated next time you boot into recovery.
- rickw and nobe1976 like this
Posted 07 July 2014 - 01:11 PM
Can the recovery flasher zip file be used to flash in flashify? I didn't realize you had to update the bootloader too. Where do i find the latest version of the bootloader for the XT926?
thanks!
Posted 07 July 2014 - 01:31 PM
- cmh714 likes this
