Every rom I try, it bootloops
10 replies to this topic
#1 nal
nal
  • 164 posts
  • LocationIllinois
  • Current Device(s):Droid Razr HD xt907/26, LG G2, Nexus 7 2012
Posted 04 July 2014 - 05:42 AM
Clockworkmod from dhacker, I normally follow the steps the rom puts up and literally every compatible rom bootlooped. I'm on the kitkat bootloader and no I will not switch to twrp due to it not having sideload (from what I've heard).
#2 cmh714
Posted 04 July 2014 - 05:59 AM
TWRP has sideload....and not sure why thats such a big deal for you....I think I have used it twice in many, many years of doing this
#3 nal
nal
  • 164 posts
  • LocationIllinois
Posted 04 July 2014 - 06:11 AM
oh, well I really don't want to risk installing it anyways
#4 cmh714
Posted 04 July 2014 - 06:13 AM
Good luck then :)
#5 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
  • LocationWhere I AM
Posted 04 July 2014 - 08:41 AM
I posted a easy recovery installer to switch to TWRP in my Omni tread. Easy as flipping a switch. Just place it on your internal or external storage and install it through current recovery. Reboot back into you current OS and when you go back into recovery it will be the latest TWRP. Make a backup of what yabgot since backups from CWR will not work on it. I can make one for CWR as well so if you want to switch back it can all be done through the recovery program on the go.
Sent from my G Harmony v2.8 using Tapatalk 2
#6 nal
nal
  • 164 posts
  • LocationIllinois
Posted 04 July 2014 - 09:43 AM
this is really odd. I got cyanogenmod working, updated to a new nightly and now my play store isn't working.
reverted back and now nothing even responds
cool
#7 cmh714
Posted 04 July 2014 - 01:13 PM
in apps wipe the data and cache for Google Play Services....
#8 Neo_mat
Neo_mat
  • 10 posts
  • Current Device(s):Motorola Droid Razr Maxx HD
Posted 07 July 2014 - 01:25 PM
Ughm, you have to wipe /cache at least when you are switching ROMs, I had Gummy to bootloop on me for ages, when I tried to switch to it from CM, wiped /cache and problem was gone. But as recommended in every single manual/guide on how to flash ROMs you should do a "factory reset" by wiping /data and /cache.
  • ibolski likes this
#9 ilinimud
ilinimud
Posted 09 July 2014 - 11:46 AM
This exact thing is happening to me on TWRP. Had to re-unlock using RSD Lite. Im back to rooted and unlocked but haven't installed a recovery because I have no clue whats going on. Flashify has 3 options, I used TWRP cuz im use to it, but the OP is having the same problem on CWM. I have never used Philz but at this point I don't think its a recovery problem. Im status code 3, root verified. Anyone have a clue what im doing wrong here?
BTW, I factory reset and wiped cache, data, dalvick, and system. This has happened on Validus 5.2 and CarbonROM.
#10 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 09 July 2014 - 04:50 PM
Chances are that some source build roms are not using the new bootloader device tree and are still using the same tree they have always used since not everyone has updated to the recent update. Omni does boot and CM does as well on the new bootloader. On can downgrade and try those flavors if one wants to run them.
  • neckchop and jl90 like this
#11 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 09 July 2014 - 05:13 PM
I would say that Is 99 percent true that is the reason...out of curiosity... What roms have you tried?
  • neckchop likes this
