[SOAK] 4.4.2 183.46.14 + 183.46.15 patch
324 replies to this topic
#21 jtommyj
jtommyj
  • 181 posts
Posted 10 July 2014 - 03:24 PM
OK using towel before applying the update works. Gonna work to narrow it down.
#22 SamuriHL
  • 43,446 posts
Posted 10 July 2014 - 03:27 PM
Wait it kept root through the update??
  • jtommyj likes this
#23 jtommyj
jtommyj
  • 181 posts
Posted 10 July 2014 - 03:38 PM
No I re fxz'd and this time before I did the update I did towel and it worked. Now I'm going to redo the update and see if towel works now.
Of course removing the gpt and tz info from the XML file.
#24 SamuriHL
  • 43,446 posts
Posted 10 July 2014 - 03:49 PM
Well, at least it's working.  Not that anyone an an HD should are at this point.  Seriously, every single one should be unlocked now!  :D
#25 jtommyj
jtommyj
  • 181 posts
Posted 10 July 2014 - 03:52 PM
OK towel just hangs again after installing update. So my next move is to re fxz, use towel, and then see if the update will go through. I doubt it but I'll give it a shot. Yeah my M 8 is my daily so I don't mind playing to see what'd going on.
#26 SamuriHL
  • 43,446 posts
Posted 10 July 2014 - 03:54 PM
That's messed up.
#27 jtommyj
jtommyj
  • 181 posts
Posted 10 July 2014 - 04:20 PM
That's messed up.
OK the update went through while rooted. I fxzd ,toweled, installed update from SD card and root held !! Waddya know.
  • spainter likes this
#28 SamuriHL
  • 43,446 posts
Posted 10 July 2014 - 04:31 PM
That's REALLY messed up.  But fascinating!  LOL :)  I can't even begin to tell you how lucky you HD owners are.  Seriously.  WOW :D
#29 jtommyj
jtommyj
  • 181 posts
Posted 10 July 2014 - 04:36 PM
  46.23KB   53 downloads
[IMG]
  • SamuriHL likes this
#30 jtommyj
jtommyj
  • 181 posts
Posted 10 July 2014 - 04:39 PM
  74.85KB   73 downloads
#31 dimqs153
dimqs153
  • 18 posts
  • LocationBandung
  • Current Device(s):XT986
Posted 10 July 2014 - 09:07 PM
Mine still on 412..is this way will survive from wifi issue on kitkat
Sent from my GT-N8000
#32 SamuriHL
  • 43,446 posts
Posted 11 July 2014 - 02:27 AM
Don't really know what you're asking.
#33 dimqs153
dimqs153
  • 18 posts
  • LocationBandung
Posted 11 July 2014 - 02:49 AM
I read review about kitkat for xt926, lot of them complaining bout wifi after update...is it true or just a rumour?they said yhat wifi able to detect wifi, but can not connect
#34 bmwh0r3
bmwh0r3
  • 13 posts
Posted 11 July 2014 - 03:18 AM
On 182(kk), I'm not experiencing this issue on wifi. Right now that's the only way I'm using the RAZR. Will experiment later by putting my Sim in it to see if that makes any difference.
#35 ibolski
ibolski
  • 535 posts
  • Twitter:iBolski
  • Google+:Ivan Samuelson
  • LocationColumbus, Ohio
Posted 11 July 2014 - 03:19 AM
I haven't had an issue with WiFi connecting. Works just fine. It does appear that the signal might be weaker in some areas where it wasn't before, but the latest soak test seems to fix that. However, you should unlock your bootloader before the new soak test becomes available. You won't be able to unlock it when the new soak test becomes available to everyone in the coming weeks.
But, upgrading to 183.46.10 gives you the ability to unlock you bootloader, so there's that. Then, if you don't like it, you can downgrade back to JB if you so desire.
#36 dnkjordan
dnkjordan
    Hazegray
  • 23 posts
  • Current Device(s):RAZR MAXX HD [Unlocked/Rooted]
Posted 11 July 2014 - 04:04 AM
Sam, do we need to run your script generator and flash the keep data script as before to restore to stock 4.4.2 or does the FXZ you provided with RSD flasher already take this into account?
#37 SamuriHL
  • 43,446 posts
Posted 11 July 2014 - 04:07 AM
What does the op say? It says if you need to get back to stock...
#38 dimqs153
dimqs153
  • 18 posts
  • LocationBandung
Posted 11 July 2014 - 04:08 AM
thanx for all the replies :)
#39 SamuriHL
  • 43,446 posts
Posted 11 July 2014 - 05:53 AM
Updated the OP to remove root instructions because root was in fact also patched in this update.  Hence, I'm closing down shop on the unlock thread very very soon.
#40 ibolski
ibolski
  • 535 posts
  • Twitter:iBolski
Posted 11 July 2014 - 06:10 AM
That was my bad on the root. I had flashed a custom boot image to remove the annoying popping noise that the KK OTA causes on some phones and that for some reason allowed Towelroot to work with the latest soak test. Once I went back to a complete stock soak test KK, after SamuriHL and Kaos stated Towelroot wasn't working, I then saw that it didn't work and I had to retrace my steps because I knew I had used Towelroot on the latest soak test. That's when I remembered that I had also flashed the custom boot image to remove the popping noise. So, when I then flashed that back and then tried Towelroot again under the latest soak test, it then worked.
So, that was my fault. Had too much going on with the soak test.
So, right now, your best and only option is to update to 183.46.10 (the first KK OTA) and unlock your bootloader now, as SamuriHL has stated. Do it now or forever hold your peace because root and unlocking the bootloader will be gone.
Of course, if you decided to take the latest soak test and apply it before unlocking, you're hosed, fubar'd, out of luck and for that, there is no going back.
As for me, I'm done with the soak and not seeing a reason to stay on it, I have now gone to the latest CM11 nightly release and loving it.
Oh, and TWRP and CM Recovery both work with the soak test. No need to go back to the previous KK OTA to flash CM11.
  • rickw and SamuriHL like this
